Home Forums Sign Making Discussions Vinyl where can i get tamper evident self destruct vinyl?
  • where can i get tamper evident self destruct vinyl?
    Posted by Carrie Brown on 19 August 2004 at 09:18
    Hello 😀
    Does anyone know where I can get this from, and can it be printed onto with a pc600?
    Tamper evident self destructible vinyl which cannot be removed in one piece. If an attempt is made to remove the label, it breaks into small fragments, clearly indicating that the label has been tampered with.
    I only need about a mtr.
    Thank you
    Carrie 😀
    Adrian Hewson replied 21 years, 4 months ago 4 Members · 6 Replies
  • Steve-Smith
    19 August 2004 at 10:25
    we use that product i think we last bought some from company called hexis
    we buy it in 380 sprocketed and print on it ok with a edge so it should be fine to print on
    i think its called ultra destructable
    hope that helps
  • Carrie Brown
    19 August 2004 at 19:43
    THANK YOU 😀
  • Adrian Hewson
    19 August 2004 at 21:36
    Hi Carrie
    Its also avail from Spandex for the edge on 380mm sproketed.
    Its good for no parking signs onto cars that have parked illegally in private car parks, it takes months to get off
    Regards Adrian
  • Andy Gorman
    19 August 2004 at 21:48
    That stuff is mental. My boss stuck some on a neighbours car when they parked in his space. Just as an example it took 2 hours to remove an A4 piece off the windscreen. It was called ultra destruct but I can’t remember who made it. Also, I remember seeing a product for warranty void labels that revealed the word VOID when peeled, but I think the manufacturing process was quite specialised.
  • Carrie Brown
    19 August 2004 at 21:50
    Thanks Adrian 😀 A client who builds and sells pc’s wants them to go on rear of the cases to stop tampering!
    Ideally we want it in 610mm unsprocketed for use on our pc600. I will give both a call tomorrow.
    Carrie 😀
  • Adrian Hewson
    19 August 2004 at 22:02
    Hi Big G this is avail from spandex as well but has limited uses
    Regards Adrian
