Home Forums Sign Making Discussions General Sign Topics where can i buy cutting matts from please?
  • BAPrint
    14 May 2013 at 19:12
    Hi Luke. You can get them from signgear.co.uk
  • David Rogers
    14 May 2013 at 20:36
    …or splash a massive £30 on a 3mm 8’x4′ of polypropylene…
    will do the average sign shop a good year a side.
  • Denise Goodfellow
    14 May 2013 at 22:12
    I bought a 6mm one from rh for £50
  • Ewan Chrystal
    17 May 2013 at 11:41
    quote :
    ..or splash a massive £30 on a 3mm 8’x4′ of polypropylene…
    where do you get them for 30?
  • David Rogers
    17 May 2013 at 13:00
    quote Ewan Chrystal:
    quote :
    Stockline plastics…mind you – that was about 3 years back as they’ve lasted that long (flipped once)
  • Ewan Chrystal
    17 May 2013 at 19:55
    Got one from them today £34 + vat + del
  • David Rogers
    17 May 2013 at 20:14
    remember & take the coating off (1 side usually) or you’ll live to regret it!
  • Ewan Chrystal
    17 May 2013 at 20:26
    ^^Thanks^^
    18 May 2013 at 17:24
    We use plasticol sheet metal, reverse side, not the vinyl/plastic coat side.
    comes in a roll of about 20 metres so can spec the length you want. its 49inch wide.
    we have used it for the past 20 years…
    the more cuts/worn the sheet has, the better its seems to get.
    you can buy it from a great many sheet metal companies, but one in glasgow we buy from sells "random end of pallet colours" for between £10-£30
    colour is irrelevant top you because you use the rear of it.
    the only thing you need to make sure is that you do not kink the sheet lifting it onto the table. its easy done if lifted wrong. this doesn’t stop the sheet being used, it just leaves a little bump in the sheet, but for your working surface its better to have it perfectly flat.
    as i said, the older it gets the better. one time purchase, never replace.
    this sheet material is the same material they build modern day factory walls and roofs with, "BEFORE" they create the corrugations in it. has a 20 year warranty on rusting and colour stability 10 years i think.
    Off the shelf size is 49inch x 10ft but they will cut to size too…
    Think the Glasgow company is Adam G Brown. cant be sure though as its been ages since we bought from them now. Based in Park Head area….
