Home › Forums › Sign Making Discussions › Neon, LED, Lighting › whats the pros & cons of led lighting?
Posted by Paul Davenport on 24 November 2002 at 23:03Well its twoish years in the planning and research but we are about to embark on a new venture with LEDs
having looked at hundreds of types and systems, we have finally settled on one to supply to the trade and end users
Ihave answered every question i can think of regarding the LEDs and there specific uses in the sign industry BUT i need a bit of help
FIRE some questions at me, i.e can it do this and that, will it go here, when i can provide a solution for the questions then I will be 100% confident in the product
please ask away no matter how simple or complicated it may be
Steve Madley replied 22 years, 5 months ago 7 Members · 12 Replies -
OK Paul, I’ll start the ball rolling for you.
How many colours do LEDS come in ?
How do they compare brightness wise with neon and fibre optics.
What are the advantages of using LEDS as opposed to other forms of lighting.
Where typically do you see them being used.
Is that enough to start you off ?
and…
what happens if rain falls onto the actual LED?
does the entire system have to be water-tight?
if one LED in a set goes down – do they all go down?
do LED’s give as bright a show in temperatures below freezing?
do LED’s glow less with age?
In the event of a power surge – will the LED’s survive?
are the LED displays left on all day and night or are they timed?
can faulty LED’s be exchanged by the customer?
can you guarantee that those fitted today will be replacable, like-for-like in a few years time or will it require rebuilding the system to accomodate the latest style of LED?
can LED’s deform acrylic letters in large numbers due to heat?
are there any specific problems associated with using LED systems in sea-front locations where they will be exposed to salt-air?
In the event of vandals smashing letters off fascias – will exposed high voltage wires be a danger until assistance arrives or the system is shut off?
can the letters or other items being illuminated by LED be washed liberally with hot soapy water and brushes etc.?
In the event of leaf and litter debris building up behind a facia letter – could this cause the LED systems to overheat or ignite the debris?
if I think of any more – I’ll post em?…lol
more soon
mikethesign
Not to be outdone ……
How do running costs compare with other forms of lighting
what are the dissadvantages of using leds
what is the typical life expectancy of an led
do people need to have any special quallification to install leds
how easy are leds to change
can colours be changed without replacing the whole system
HHMMMM now i think i waite and see what replies come here before getting involved… 😆 😆
but on a serious note paul… if they are good and at the right price i would be interested in starting to use them. ive been looking at leds as you may know for a while now… so if your becoming a supplier… good stuff 😉
Are they for backlighting acrylic boxes? or for decoration only.
Are they programmable into patterns?
240 v or is a transformer required?
What is mimimun order qtys?
YEAAA
keep em coming
Mike theres a good one or two in there mate !!!!!!
OK heres some answers to those questions
white, green, cyan, blue, royal blue, red, red/orange and amber/yellow as well as being able to mix colours ie red and white to give pink light
Very well, starting brightest first you get red/orange, red, amber,cyan, green, white, blue and royal blue the reds out shine neon, whilst the whites and blues are comparable but you need to use a few more leds per metre
I wouldent compare to fibre optics in signs yet as i think that optics arnt really that usefull in illuminating signs(ask me more if you like)
cost, easy installation, durability, re-usable,power savings, easy to design into projects
Definatly in channel letters, i have already decided that red LEDs have replaced neon for typical illumination properties and soon the other colours will go that way
Well that should keep you happy, now onto mikes encyclopedia of questions
Here we go
It could cause a temporary short circuit, but would not damage the LED or cause a dangerous situationdoes the entire system have to be water-tight?
Ideally yes, water ingress could cause a problem with the connections over time, the use of a silicon grease on the connectors would help this matter, std channel letter construction should keep the elements away from the LEDs
This would happen on RED LEds but would be a very rare situation
Brightness will increase in lower temperatures and still light instantaniously
Yes typically around 60 000 hours they start to lose light out put, but not drastically
the electronic driver wil protect against this
Customer choice, It can be a fully programable system
Yes, simple plug and play connections enable ease of maintenance
they should be available for around 5/6 years,the next generation of LEds will be brighter, but you could dim down the light out put to match the existing systemcan LED’s deform acrylic letters in large numbers due to heat?
the heat generated is less than you would get from comparible amounts of neon
Direct contact with salt spray tends to corrode contacts, a conformal coating is available at an additional cost, having had first hand experiance of manufacturing signs for the sea-front (DT signs- Blackpool), every sign has to be made as watertight as possible, if you apply this to LED signs then you will be OK
The systems run at 12-24 v max so there is no danger, short circuits would be automatically shut down by the drivers, it should be connected up to current breakers anyhow which would trip in the event
You can wash the letters, but try to keep the leds dry as you would with neon etc
Max temperature in a worst case scenario is 100 deg so there is no fire risk
well thats mikes done
and a few more
lets compare to neon, i am told about 1/3 of the costwhat are the dissadvantages of using leds
Them being new technology in a way, and not fully understood other than that i will let you know
between 50000 and 100000 hours
Nope although you need to know what youre doing with wiring etc
Easier than typing this
Yep, as there plug and play moduals
Is that it
one more point to add
We will also be using/supplying a spray on conformal acrylic sealer to help protect against water / moisture ingress, this came about after an inquiry on the sea front !!!!!!!
Paul Have you set up suppling led’s yet…I have a job coming up for them…I understand a bit about LED…We fitted Pizza Hut Restaurants with them for a big nottingham company…using sloanled….ordered in america…made in singapore…shipped to austrailia then to us…We had a guy come from america to train us for the first one in Cardiff..So if you have got stock of possibly blue/turq I would be interested…We don’t need a lot its for undercounter lighting…
While were on the subject can you cross fade LED????? -
I’ve seen the LED moving message signs using cross-fade and it’s used in disco/fx lighting, so, yes.
