Home Forums Sign Making Discussions Vinyl whats the easiest way to laminating small graphics ?
  • whats the easiest way to laminating small graphics ?
    Posted by Graeme Speirs on 27 July 2006 at 22:14
    hi,
    have the chance to quote for a small point of sale job, I can print this via my cadet and mount onto kappa or foam x pretty easily, HOWEVER.
    my question is can I laminate these by hand, they will be fairly small at 50 cm x 40 cm?
    Also should I print these then laminate and then mount? or print, mount and laminate?
    would appreciate some feedback.
    graeme
    Colin Hibbitt replied 19 years, 3 months ago 6 Members · 11 Replies
  • 11 Replies
  • Cheryl Tissington
    27 July 2006 at 22:18
    I laminate without a machine at the moment.
    I print, leave it overnight before wet applying the laminate and then mount onto whatever its going onto.
    Hope that helps
    Cheryl 😀
  • Graeme Speirs
    27 July 2006 at 22:24
    thanks cheryl, what is the max size you can laminate to without using a machine ?
    graeme
  • Andrew Boyle
    27 July 2006 at 22:26
    wet apply laminate by hand [using a solvent based laminate]……….
    then trim print……..and mount as normal……..no problem 😀
  • Cheryl Tissington
    27 July 2006 at 22:31
    Graeme
    I laminate up to the full width of the material and whatever the length is.
    Its a bit of a handful, but you just need plenty of soapy water and an extra pair of hands. :lol1:
    Cheryl
  • Graeme Speirs
    many thanks andrew, can you recommend a solvent based laminate and supplier?
  • Andrew Boyle
    27 July 2006 at 22:33
    Maybe buy Oracle 3651 then you can use it for printing on clear as well…gloss though 😀
    Europoint
  • Gordon Forbes
    28 July 2006 at 01:41
    Get the Oracal laminate for 3651 290G I think it is
    makes a fool of the clear and it puts a good gloss on it
    Apply wet though as you don’t get a second chance at all
    Use a proper app fluid as well while you are at it
    Thats my opinion
    Goop
  • Cheryl Tissington
    28 July 2006 at 13:18
    I use lots of Rapid Tac Application Fluid.
    It allows the laminate to flow across the printed graphics and it’s forgiving if you need to lift and re-apply.
    Its easy the push all the air & water out with a felt squeegee.
    Cheryl
    28 July 2006 at 15:13
    why bother laminate POS signage? unless i am missing something were the laminate is a must… ide leave it.
  • Graeme Speirs
    28 July 2006 at 16:02
    I agree rob, it was in the tender doc though so just covering myself.
  • Colin Hibbitt
    30 July 2006 at 19:50
    HI GRAEME,
    WE USE BOTH METHODS
    ON LARGER JOBS WE LAMINATE THROUGH OUR 760MM LAMINATER
    AND ON SMALLER JOBS WE JUST USE WATER AND WASHING UP LIQUID SPRAY PRINT AND LAMINATE WITH ULTRAMARK 5700 TRANSPARANT FILM
    IT WORKS GREAT AND HAD NO PROBLEMS FOR YEARS
    ALWAYS BEST TO LAMINATE FIRST PRIOR TO MOUNTING ON BOARD ITS A LOT EASIER
    COLIN
