Home Forums Sign Making Discussions Vinyl whats the difference between Cast vinyl & Vehicle wrap v
  • whats the difference between Cast vinyl & Vehicle wrap v
    Posted by Mobilewraps on 16 May 2003 at 00:36
    Can anyone please tell me the differences between cast vinyl (such as Avery 1005 EZ & 3M controltac 180) and vehicle wrap vinyl (like the KPMF stuff)?
    Is it the same or is there some difference?
    Scott
    Robert Lambie replied 22 years, 7 months ago 3 Members · 5 Replies
  • John Childs
    16 May 2003 at 06:22
    Take a look here Scott…..
    http://www.uksignboards.com/viewtopic.p … ap&start=0
    hopefully it might answer some of your questions.
    Regards – John
  • Mobilewraps
    16 May 2003 at 06:34
    Thanks John,
    It has helped a little, but I guess what I want to know is, does vehicle wrap have more felxability/stretch than cast vinyl or is it the same stuff?
    Scott
  • John Childs
    16 May 2003 at 07:06
    I’m no expert Scott, but I think that the concensus is that they are different.
    Yes, they will both stretch an awful long way, but the difference is that whilst cast has a low memory, wrapping vinyl has even less and is therefore less likely to shrink back.
    Retaining opacity when stretched is another consideration, and is why wrap tends to be a bit thicker than cast.
    Also, as Martin pointed out on the other thread, if they are they are the same stuff why would there be such a price differential?
  • Mobilewraps
    16 May 2003 at 12:52
    That makes sense.
    Do you know who the main manufacturers of vehicle wrap are?
    17 May 2003 at 08:37
    hi mate..
    johns brief reply is probably better put than one of my rabbling replies.. 😆
    in my vew they are very different.. cast can be pushed & work well. although i wouldnt use one as oppossed to wrap vinyl.. this is just my opinion of course. 😉
    sources for you in oz.. well KPMF is from the states originaly so that shouldnt be any probs to locate. MACTAC is another, i believe big in the states too. although manufactured in Belgium.
    i would suggest to anyone, “buy in a few metres of each and play aorund with them. get a feel for them and decide what works best for you!
