Home Forums Sign Making Discussions Vehicle Wrapping whats the best way to print a whole roll of vinyl?
  • whats the best way to print a whole roll of vinyl?
    Posted by Simon Polakof on 2 June 2010 at 20:40
    We have to print a hole role for the first time using an uptake unit to collect the printed material.
    Seeing that I never done this I would like to know how you out there go about it when it comes to letting it dry before laminating it. Do you let it dry in the uptake role?`How many days, is it enough with the regular 48 h? I’m a bit uncertain seeing that it’s all rolled up in the role.
    Peter Normington replied 15 years, 4 months ago 10 Members · 22 Replies
  • 22 Replies
  • Matty Goodwin
    2 June 2010 at 20:50
    Hi Simon!
    Your English is very good but it’s ‘whole roll’ not ‘hole role’!
    In answer though we slacken the vinyl on the roll to allow the vinyl to breathe. Then we put it in our drying cupboard to gas out.
    Matt
  • David Rogers
    2 June 2010 at 20:52
    Does it HAVE to be one continuous graphic? And in light of that…can you APPLY an entire roll in one go? If not…what’s the point of running 45m of continuous print…and will your uptake spooler handle it…
    I’d be tempted to break it down into more manageable chunks. Loose roll & stand to outgas for your 24-48…and laminate away…
  • Matty Goodwin
    2 June 2010 at 20:55
    Good point David, never read into that! Of coarse there must be breaks in the print. If not please don’t ask me to fit it!!!!
    Matt
    2 June 2010 at 21:01
    Matt – your English is very good too ….but it’s course not coarse 😕
  • Matty Goodwin
    2 June 2010 at 21:13
    Aaarrghhh! Me gunna go bak to skool!!
    2 June 2010 at 21:18
    when yoos wrap like matt no need to
    go to skool, jus sa it as it, cors is cors,
    jus bcors
    nuff sed
  • Jamie Wood
    2 June 2010 at 21:20
    As Matty says, stand the roll on it’s end – we use a roll end to stand it on. Leave it
    quite loose to gas out for 24 – 48 hours before laminating. We do this all the time and
    have never had any issues. The take ups on our Mimakis handle a full roll with no problem.
  • Gwaredd Steele
    3 June 2010 at 08:30
    Peter: Can you change your profile pic to one of you wearing a baseball cap back to front whilst throwing out a gangsta sign please?
    Cheers,
    Gwaredd.
  • Gwaredd Steele
    Double post
  • Simon Polakof
    3 June 2010 at 16:15
    Thanks every one!
    You are right it’s whole and not hole…. 🙂
    The reason I was thinking of printing the whole role is because we probably are going to do a whole bus and I thought that it might save me some time to do it all in one chunk….
  • Martin Oxenham
    3 June 2010 at 20:36
    I Can’t believe that any friction fed printer could go a whole roll without running off. I know our old Seal laminator would’nt go more than five metres in one go without needing the print reloading.
  • Jamie Wood
    3 June 2010 at 20:58
    quote Martin Oxenham:
    Believe it. We do this regularly, and then laminate the whole roll as well.
    On a Seal.
    3 June 2010 at 21:04
    me too
    3 June 2010 at 21:07
    quote Jamie Wood:
    On a Seal.
    be careful the rspca will be after you!
    I do the same though, how does being friction fed make it run off?
    if the roll is squared up to start it should be no problem
  • Jamie Wood
    3 June 2010 at 21:11
    quote Peter Normington:
    :lol1:
    3 June 2010 at 21:13
    i couldn’t get anymore than five meter’s on the cadet then it went off…five if i was lucky, in fact i have never in all the years of signmaking using plotters and printers have I had one that did a full roll…..id be jumpin for joy if it did 😀
    3 June 2010 at 21:52
    Seriously
    when I load a 50m roll of vinyl in my printer, I do not expect it to go off more than 5/10mm for the whole roll.
    I do not have a top of the range laminator, but again I would not expect it to run out more than 20mm on a full roll.
  • Gavin MacMillan
    4 June 2010 at 07:33
    Agreed, any more than Peter mentions and either you are not loading it straight or there is an issue with the machine putting down uneven pressure
    4 June 2010 at 09:28
    quote Gavin MacMillan:
    well i must be stupid then :nana:
  • Gavin MacMillan
    4 June 2010 at 09:44
    More likely you have an issue with your pinch rollers/grit roller. I have also found in the past that some not so big brands of vinyl are not always slit very straight and that never helps!
  • Martin Oxenham
    4 June 2010 at 21:27
    Peter what laminator do you have ?
    4 June 2010 at 21:52
    Martin
    its a jet mounter
