Home Forums Sign Making Discussions Vinyl whats the best way to make double sided window stickers?
  • whats the best way to make double sided window stickers?
    Posted by Ian Bingham on 21 November 2007 at 21:06
    I’m after some quick advice, I need to make 60 double sided window stickers, A4 Blue background with white text and a logo
    Whats the best way
    HELP
    Ian
    Peter Normington replied 18 years ago 6 Members · 20 Replies
  • 20 Replies
    21 November 2007 at 21:14
    Ian
    If its spot colours,
    a gerber may be the answer, print reverse on clear, 2 coats of white then print normal, I found the white foils from europoint (forget the make) were denser than spandex ones, and worked well
  • Ian Bingham
    21 November 2007 at 21:22
    Only have a versa camm
    would like to do it in house if poss as budget is tight
    Ian
  • Nick Minall
    21 November 2007 at 21:25
    well you could reverse print on to clear then print on to white and then stick them together so you can stick it on to the window 😀
    21 November 2007 at 21:28
    I doubt if its an option Ian, even if you could print double sided, you would have problems with alignment.
    I would be interested if any one has a solution,
    Nick that may be the answer…
  • Ian Bingham
    21 November 2007 at 21:34
    tend to agree with you Peter, think i might be clutching at straws here, but it was a case of opening my mouth before the brain was in gear," of course we can do that"
    Ian
    21 November 2007 at 21:37
    Sorry, I posted before reading Nicks suggestion
    In theory it should work, but you would need some fairly opaque white, so the print would not show through though.
  • Nick Minall
    21 November 2007 at 21:56
    you may get away with gray back vinyl depending what the print is?
    21 November 2007 at 22:03
    Nick, grey back would show through the clear?
  • Nick Minall
    21 November 2007 at 22:06
    well it depends what colour you need in the end, maybe ok if you are completely printing it? like on silver vans
  • Peter Munday
    21 November 2007 at 22:29
    Somebody posted the answer on here a while back, it goes something like this. Print blue negative onto clear self-adhesive placing cutting registration marks, remove and laminate with white when cured. Replace in machine and contour cut telling it to stop at the start point 😮 then press base point and send the blue file again but in forward, and hey presto! double sided stickers.
  • Nick Minall
    21 November 2007 at 22:39
    the only problem with that is if when you put it back in to cut/print if you have not put it back in square, it will cut ok as it will correct for it but it will not correct when it prints.
    Nick.
  • Peter Munday
    21 November 2007 at 23:14
    It will Nick, as when it finishes cutting it returns to the start point where you tell it that’s the base point to start printing from.
  • Peter Munday
    21 November 2007 at 23:18
    Nick it was discussed here http://www.uksignboards.com/viewtopic.p … d+printing
  • Nick Minall
    21 November 2007 at 23:25
    when you put it back in if its not square it will correct for cutting on the marks, you then set a base point, that will set that point but if its not square the outer 3 point may be out, so the print not be corrected as it will be for cutting, so it may not print in the right place.
    21 November 2007 at 23:27
    I don’t think there’s an easy way to do this.
    I would print onto clear, then laminate with white vinyl, then contour cut – (half the job is done).
    Then I would print and contour cut onto grey backed white print vinyl – (other half of job done).
    Finally – manualy overlay 2nd set of prints onto first set of prints to complete.
    21 November 2007 at 23:30
    or cheaper way to do the job…get it screenprinted 😀 and it will be spot on 😀
    21 November 2007 at 23:31
    again phill, i cant see how the grey back would work, as white text is part of the design.
  • Nick Minall
    21 November 2007 at 23:34
    forgot the white text bit, Nicola way is best.
    21 November 2007 at 23:40
    quote Peter Normington:
    Ans.
    1/ Laminate the clear with white vinyl (not grey backed) (note-print the blue background on the clear).
    2/ On 2nd part use grey backed vinyl (as a light block) to repeat the print design on the non sticky side (as before – include printing the blue background)
    Then manually put the two prints together – the result will have three layers of vinyl – first clear, middle white, last white (grey backed)
    Hope that makes sense – and yes it will work 😀
    21 November 2007 at 23:48
    sorry Phil, missed a layer, 😳
