Home › Forums › Sign Making Discussions › Vinyl › whats the best way to go about backslitting the liner?
Posted by Richard on 23 February 2006 at 14:49I tried searching, but didn’t turn anything up.
Does anyone have any ideas on the best way to go about backslitting the liner of large quantities of small plotter cut lettering (approx finished sheet size 200x60mm).
I’d be grateful for any handy hints.
Richard
J_J_O replied 19 years, 8 months ago 5 Members · 7 Replies -
Do you mean like ‘crack-back’. (usually seen on commercial safety stickers). I get the feeling that that stuff has a pre-spilt liner before the adhesive vinyl is rolled with it.
if you mean slitting it so you can tape n the middle, then i usually lay it flat, face down, peel back the liner, cut it off, and re-lay it on with a couple of mm overlap, make sure the liner is bigger than the design and has the app tape on to keep it all in place (easy forgotten on a flood sheet !),
i have done it using a slit knife, but the problem is lifting the liner clear in the first place !
if anyone has a better idea, i’d be pleased to know too !
edit: been jumping in too quick today !! no idea on small stuff ! what he said above ! 😳
Hello David and Hugh, unfortunately not crack-back. It has to be plotted and then backslit.
With a new scalpel blade it’s quite easy, but I don’t really fancy doing a thousand or so with that degree of precision, or picking up and putting back down again!
I think it’s a bit too small for a snitty
Richard
Now this might sound a bit mad – but I’ve just given it a go.
Using your blade holder (set to the right depth – trila & error) & a straight edge score/cut the liner on the reverse.
IT WORKED…sort of.
Granted I did blow a couple of bits of pre-cut letters trying it.
Give it a go, nothing to lose but your sanity.
Richard,
Do you mean something like the backing slitter?
You can adjust the depth of the knife with this one, I use these for cutting the backing of (cold) laminate.Regards
Jaap-Jan
you can have a laser cut run across the backing sheetKev
A laser cut run???
Sounds interesting, can you give some explanation or links?Thanks,
JJ
