whats the best way to fit a Large Glass Etch Film Job
Hi All
I have an order to do a large glass etch film job.
It is going in internal office windows that are 2000mm high. There is a horizontal band of 1200mm that runs in the middle of the glass. It has horizontal stripes that are 20mm wide with a 10mm gap in between. It is gong to be a night mare to cut as the vinyl cutter has to run all the way up then all the way down for each strip and there are like 50 across the 1200mm. We have 165mt to do like this it is 3 floors of offices.My first problem is what vinyl to use. I have given them samples and they want a plain grey type. Not the one with the sparkle. They also want the cheaper 3-5yr not the 7-10 year cast. Because of the size of the job and the application time I’m not too sure which vinyl to use and what app tape to use. I want it to be as easy as possible as well as cheap as possible so i can maximize profits.
My options at the moment are:
I use Avery crystal Glass Film with a med tack app tape and apply wet only problem it it takes long to dry and also sometimes when squeegeeing, a strip comes away from the app tape and then it ends up skew. then you have to manually straighten them which could take hours. I want a high enough tack so that it doesn’t move when applying and a low enough tack so that i can remove it easily at the end.The next option is to try and apply dry. Has anyone had success with applying dry. What method do you use. My experience has told that you often get uneven pressure marks on the adhesive side once applied. Do they ever go away? Also what squeegee do i use. Can i make a wider one successfully.
the last option is. Mactac has released a bubble free sandblast film. It is
30% more expensive but it could solve my application problems. Because with my experience if you try and pop a bubble which you will almost certainly have in this large quantity it ends up leaving a little cut mark that splits open. Also i am worried about cad cutting this bubble free. It has been made for printing onto. Has anyone cut bubble free vinyl before. Does it weed successfully.Would appreciate some of your advise on this as i don’t want to go and purchase all this vinyl and then find once it is all cut that i have application nightmare.
