Home Forums Sign Making Discussions Vinyl whats the best way to cut around door handles?
  • whats the best way to cut around door handles?
    Posted by ian rankin on 6 August 2004 at 08:35
    We have do apply vinyl graphics around a vehicle door handle.
    Any tips as to how best to achieve a nice cut edge around the handle
    would be appreciated.
    Ian rankin
    Cookster replied 21 years, 4 months ago 2 Members · 2 Replies
  • Rod Gray
    6 August 2004 at 08:42
    Ian,
    The safest and easiest way is to plot and weed them and then trim the app tape out of the hole so the handle doesn`t interfere with the application. This takes a little bit of setting up but gives 100% accurate results.
    The trickier way is to manually cut them with a very sharp scalpel once the vinyl is applied. Use a metal ruler for precison and go very slowly around the corners.
    Rod
  • Cookster
    6 August 2004 at 08:57
    Hi Ian,
    I just manually cut round them with a scalpel, but to aid matters a bit get an off-cut of magnetic vinyl.
    You can place in position and cut along the straight edge, i find it easier than trying to hold a ruler in place.
    Also u can cut many radius templates etc out of the magnetic for going around locks/door handles.
    They might take a bit of time but u only need to do it the once and you can re-use them again and again.
    Hope this helps, Joe
