Home Forums Sign Making Discussions Neon, LED, Lighting whats the best way to apply 3D letters onto uneven wall?
  • whats the best way to apply 3D letters onto uneven wall?
    Posted by Alistair Richards on 25 June 2008 at 17:00
    I have been asked to price for some stainless 3d letters onto a cornish stonework wall. The wall has some quite deep joints, and I can see it may be a problem fitting. I have suggested putting a sign panel behind but I don’t think they are too keen on that idea?
    What’s the best way? Chemical anchor and big heads? How?
    Or does someone know a supplier or how to fabricate those one you see with two rails behind?
    Thanks in advance, more questions probably to come. :lol1:
    Dan Osterbery replied 17 years, 5 months ago 6 Members · 9 Replies
  • 9 Replies
  • Ian Johnston
    25 June 2008 at 17:56
    is it proper stainless your looking for, if it is then get threaded bars put on the back 10mm long, drill you holes as normal ,then fill with a polyutherane adhesive, and push your letters into the holes untill the required depth, i’ll post some pictures later to show how to make it work.
    we use applelec for the letters and they can supply as above no problem
    ian
  • David Rogers
    25 June 2008 at 18:50
    quote Ian Johnston:
    ian
    Maybe best make that a bit more than 10mm…. 🙂
    Have used this system on several occasions. Studs on the rear that are about 50mm past the return (if any) and using either Evostik Serious Stuff (for a longer working period) or Hilti’s 2 part bond…work quick though as that goes off FAST. I normally ask for spacers to be supplied to slip over the studs to get it evenly off the wall (if flat)…a little trickier on an uneven surface – but not impossible.
    25 June 2008 at 19:53
    Advice given is good,
    but a tip to get the letters at even height from the wall.
    Run a line between 2 screws, placed top and bottom of the text, to align them
  • Alistair Richards
    25 June 2008 at 20:13
    Thanks for the advice,
    I think that’s answered everything I need to know, good tip Peter about string lines.
    Just another quickie, if the threaded stud at the back of the letter is about say 10mm diameter, what size hole would you drill in the wall to give some room for adhesive, about 12mm? and are the stainless letters quite heavy and need supporting while glue is setting off?
  • David Rogers
    25 June 2008 at 20:48
    Good tip there from Peter re: string.
    the studs are normally only 5mm in diameter and soldered to the rear.
    I’d be using an 8mm hole to the desired depth and half filling it…any overspill is a right bugger to remove if it’s going to be visable…ie. just pump in a good blob.
    The secure the letters…like stopping them ‘settling’, bend the studs EVER SO SLIGHTLY to splay them out or pull in on the sides of the holes.
    Most 3D stainless letters – whilst looking heavy are incredibly light for their size…2mm flat cut is generally never a problem either.
  • Ian Johnston
    25 June 2008 at 21:13
    quote David Rogers:
    quote Ian Johnston:
    ian
    sorry never checked meant 100mm :lol1: :lol1:
  • Peter Dee
    26 June 2008 at 07:17
    After drilling the holes you have to get the dust out or the goo won’t adhere.
    Get a small tube and insert it to the bottom. Blow through the tube to eject the dust.
    Just watch your eyes when you do this as there will be a lot of it.
  • Ian Johnston
    26 June 2008 at 20:14
    i have posted some pictures on another thread to show how they can work. the really small letters at the bottom are mounted on a flame polished piece of perspex and threaded bars hid behind them, the undulations on the SPA wall were up to 75mm.
    Ian
  • Dan Osterbery
    3 July 2008 at 17:06
    we use 10mm threaded bar, drill a 10mm hole with a 10mm hilti bolt that the bar threads into and as you screw them up they open out and grip,(sorry no idea what you would call them in english) and on the bar use two nuts to adjust the letters so they are flush and all level and the second nut locks them off! and the string line is a great tip, works a treat!
    can send a photo of one if your interested?? If someone explains how to attach photos!!
