Home Forums Software Discussions Corel Software whats the best way of saving files please?
  • whats the best way of saving files please?
    Posted by Derek Hunter on 25 June 2006 at 20:33
    Hi Guys
    Decided to give corel draw a bash, im currently using CS2 for me graphics but decided to try corel, now.. my problem is when i tray and save my graphic as .EPS for some reason it will not load into vinyl master pro can anyone tell me what the best way to save this as? i have some options
    postscript level 1
    postscript level 2
    post script 3
    thanks
    Shane Drew replied 19 years, 6 months ago 4 Members · 4 Replies
    25 June 2006 at 22:10
    try AI (Adobe Illustrator format)… EPS is a large format.
    Although if ur a CS2 user and can run fast at it, stick with it.
    26 June 2006 at 07:31
    As Dave said try AI format – export as a fairly low version of AI and make sure the ‘ simulate complex fills’ is clicked off (I click off ‘simulate outline effects’ for good measure too) If you do need eps I assume you mean export not save use level 1. The higher levels support things like transparency and more points I think but for cutting level 1 should be fine.
    Alan D
  • Chris Lambe
    29 June 2006 at 12:23
    What alan said is spot on 😉
    29 June 2006 at 12:48
    quote Chris Lambe:
    :praise1: Alan is da man when it comes to Corel….
