Home Forums Sign Making Discussions Neon, LED, Lighting whats the best way of lighting this rotating sign?
  • whats the best way of lighting this rotating sign?
    Posted by pilot on 12 February 2007 at 19:45
    UPDATE 2007-02-14
    UPDATE:
    The customer wants now, the red fields are moving like this:
    every help very appreciated on this:
    I need to turn-on the red fields of the roulette gradually:
    Step 1: red 5 on
    Step 2: red 16 on
    Step 3: red 1 on
    etc…
    Step 9: red 3 on
    Step 10: all red fields off
    and again
    Step 1: red 5 on
    etc…
    It should symbolize the movement of the roulette, so the interval between turning-on the fields should be shortly. It is a double-sided, 14 CM (app 5,5") deep sign, so I think, LED is not really a choice.
    The light source in the red fields is a 15 CM (app 6") neon in every red field.
    What is the best way to achieve the wanted effect?
    Thank you all.
    pilot replied 18 years, 9 months ago 3 Members · 5 Replies
  • Rod Young
    13 February 2007 at 02:26
    For starters, the basic electronic circuit would be based on a LED chaser. If you want to get fancy, you could tweak it to randomly fire 1 out of (say) each group of three.
    I don’t know how convenient electronics hobby shops are for you, but they would have a LED chaser, and perhaps they would have circuit diagram for roulette wheel project, like you are asking about.
    Actually, I just did a search for keywords of "circuit diagram roulette" and found a number of references. Here’s the first one:
    http://en.wikipedia.org/wiki/4000_serie … c_Roulette
    Cheers,
    Rod
  • Marko YYZ
    13 February 2007 at 02:51
    Seems like there is some info missing here. So the sign is 14cm deep – what is the diameter of the entire sign? Do the light have to chase in opposite directions – ie correctly on each side of the sign?
    You’re better off using either an neon chaser system (if you insist on neon), or use Red LEDs controlled by either a DMX controller, or a standalone LED control of some sort.
  • pilot
    14 February 2007 at 07:26
    Thank you guys!
    For this job we have to stay on neon, since the tubes are already produced.
    Since the sign is double-sided, the graphical part is color-identical on both sides (red/red). I have chosen a neon, because I can illuminate both sides whit one neon.
    I have googled for neon chaser and found this:
    http://www.digitallighting.com/animatio … /mcser.htm
  • Marko YYZ
    14 February 2007 at 14:45
    I’ve seen those chaser’s used in the past, and it should do the trick for you. Even though you may have to have more than one ‘number’ illuminated at a time… it will still give you a convincing enough chasing red effect.
  • pilot
    24 February 2007 at 19:09
    The job is done.
    The movie is to see on members portfolio.
