Home Forums Printing Discussions General Printing Topics whats the best way of doing back lit menus please?
  • whats the best way of doing back lit menus please?
    Posted by Peter Normington on 22 March 2009 at 19:53
    Whats the best way to do them?
    I did some last week but was not happy with the results.
    I took on the job to help someone, as they had a tight deadline to work to, out and it has now come back and bit me in the bum.
    I used clear vinyl double ink pass, and high quality, to avoid any banding issues. I then mounted on customer supplied 4mm white acrylic, which was very translucent, prints were not to a standard I would have liked, and looked washed out, especially a faded background in the design.
    What materials do you find give the best results? substrate and print,
    and any tips on print settings?
    James Langton replied 16 years, 9 months ago 3 Members · 4 Replies
  • Frank Horner
    22 March 2009 at 21:18
    When I did some backlit menu photo prints I bought backlit media which is opaque and semi rigid. The finished items were sandwiched between an opal sheet and a clear sheet. This also means they are easy to change when the time comes.
    I think the backlit media I used came from Hexis.
    Frank
  • James Langton
    22 March 2009 at 23:32
    I’ve found printing onto clear using a normal profile works fine ours is set to 4 pass which is actually 8 pass because its a 2×4 machine. Recently did one where it was printed onto clear and then mounted onto opal looked 100 times better than the back lit printable stuff as it seems to have an off white look to it.
    22 March 2009 at 23:41
    4 pass or 8 pass is not what I meant, the ink still looks washed out, even at 16 pass, on clear, but two layers of ink does make the image better, not great, but better.
    Sorry, if I am confusing passes with overprint
  • James Langton
    23 March 2009 at 07:57
    I knew that was just saying how we print onto backit.
    Strange, because we never usually overprint, what profile and media are you using.
    James
