Home › Forums › Sign Making Discussions › Vinyl › whats the best way of cutting magnetic sheet?
Posted by Paul Seamer on 28 November 2007 at 16:11Hi Guys.
Don’t no if this is a silly question. How do you cut Van magnet? to make sure that there square?
Paul
Nicola McIntosh replied 17 years, 12 months ago 11 Members · 14 Replies -
Hi Peter.
So it is as easy as that. I tried with a Stanley knife on a test set and it was to straight but i wasn’t using a set square.
Thank again
Paul
Paul,
Use a new blade to ensure the cleanest cut and do a light pass of the blade for the first cut.
Nick.
i agree,
set square (though not essential, it makes sure), new stanley blade, straight edge. i usually do it with one cut.
for the corners i use all sorts of things! small wd40 tin (about a 2" diameter) makes the best size radius, then use a new scalpel blade to cut very carefully by hand along the line, takes a little time and patience, but i find that the best way. if you’re unsure, then practice some radius corners on the offcuts.
Hugh
I find for most jobs i score the surface and then tear from the front to the back and its good enough
Rich -
Hi, to round the corners I bought a 90o curved wood chisel from a boot market for £2 works a treat for rounding corners on many materials and if you blunt it you can just resharpen.
Neil -
quote :I bought a 90o curved wood chisel
always wanted to try that but could never find one 90 deg.
cutting mags – straight edge and Craft knife. but make your weeding box the size of the finished mag. tape and cut to the edge. fit lettering and cut around the application paper before removal. all square and correctly placed.
quote Chris Wool:quote :I bought a 90o curved wood chisel
:doh: Why didn’t I think of that?? lol
Never tried this, but will it not go through a plotter?
might have to do a few passes but would it then just not pop out or possibly have to have the last little bit cut with a blade?
that way you arent restricted to squares and can round the corners etc?
Call me stupid if its obvious you cannot do this, I just wondered. -
I tried it in my plotter last week, will only work if the plotter has an ally or plastic bed though. but I got a voltage error message after the mag had gone back and forth so presumed it was interfering with the circuit board chips,
It would wreck blades in a fews cuts though iwould think, unless there is a heavy duty one available?Peter
It is pretty thick really eh,
a heavy duty rotary trimmer would be good I imagine.
But the A3 ones for paper are expensive enough.
Have to invent one and get on dragons den. -
I use a Rototrim pro, it will cut magnetic but it tends to run off a bit
quote Peter Normington:I tried it in my plotter last week, will only work if the plotter has an ally or plastic bed though. but I got a voltage error message after the mag had gone back and forth so presumed it was interfering with the circuit board chips,
error my have been due to acceleration or speed to high its heavy stuff compared to vinyl
quote Richard Urquhart:I find for most jobs i score the surface and then tear from the front to the back and its good enough
Richyep i agree thats all is needed….too much force makes you go off line..especially if your not confident in cutting with a knife 😀
