Home › Forums › Sign Making Discussions › Traditional › whats the best method of painting stainless steel? Traditional whats the best method of painting stainless steel? Posted by Ratcliffe on 3 October 2006 at 11:56 Can anyone tell me the best method of applying paint to stainless steel plaques that have been Acid etched using a vinyl mask, thanks Neil Churchman replied 19 years, 1 month ago 4 Members · 4 Replies 4 Replies Harry Cleary Member 3 October 2006 at 13:18 I would presume you would need an ‘etch primer’ available from car body shops, make sure to check that your final paint is compatible. Hope this helps Ratcliffe Member 3 October 2006 at 14:56 Thank you Harry. I will investigate. Cheers Paul Signetch 😀 Andy Gorman Member 3 October 2006 at 15:09 I assume you mean to fill the etched area? I have sprayed them before, using car spray cans, before removing the vinyl mask. Neil Churchman Member 25 October 2006 at 07:45 To paint brushed stainless steel you need to apply an etch primer to metal that’s degreased with meth’s and slightly warm (not cold). After the primer has dried, check adhesion by sticking masking tape to the surface and ripping off. If the primer doesn’t come off you’ve proved the primer has bonded successfully, then you’re ready to spray your next colour or base primer. Log In to Reply Log in to reply. Public All Members My Connections Only Me PublicAll MembersMy ConnectionsOnly Me Public All Members My Connections Only Me Log In to Reply Start of Discussion 0 of 0 replies June 2018 Now
