Home Forums Sign Making Discussions Vinyl whats a suitable material for skips?
  • whats a suitable material for skips?
    Posted by dannyflint on 7 March 2006 at 12:36
    Hi , someones just phoned. They have 20 skips, and they want a stencil making, so that they can spray paint their details on the sides of the skips.
    Any idea which the best media is for this?
    We have some METAMARK PAINTMASK but not really sure, if it can be taken off and reused after one spray.
    Any help on this matter would be most appreciated..
    Danny
    Mike Grant replied 19 years, 8 months ago 9 Members · 11 Replies
  • 11 Replies
    7 March 2006 at 12:40
    I use 1mm fourex and get the stencil cut by a cnc rounter. works a treat.
  • Rod Gray
    7 March 2006 at 12:47
    Magnetic Vinyl.
    There is a demo in the hints and tips section of this site.
  • dannyflint
    7 March 2006 at 12:49
    cheers shane, we have a small router.
    I think he’s after a quick cheap solution, and that seems like we’d have to charge quite a bit, especially if he wanted the letters large
    Anyone else got a solution using the vinyl cutter, not a router
    Danny
    7 March 2006 at 12:51
    i’d go the mag route, use the usaf stensil font if you have to (ready stensil !) or cut out of some thin foamex, wouldnt take an hour with a jugsaw ! just stick some cheap vinyl on it, and cut it out !
    7 March 2006 at 12:53
    quote dannyflint:
    Danny
    vinyl is a once only use tho danny, so over 20 units, the fourex would be better value coz you only make one. Got to be cheaper to make one for multi use, than 20 for single use. Don’t you think?
  • dannyflint
    7 March 2006 at 12:54
    CHEERS GUYS
    Rob, if you’re reading this I still cant login to my UKSG account ( login: kate and danny ), which is why I’m using my old standard account.
    PLease fix this so I can view the tips and tricks…
    Danny
  • Glenn Sharp
    7 March 2006 at 13:06
    We have had good results by building up layers of vinyl.
    Cut 4 or 5 layers of your image, apply them on top of each other whilst the 1st one is still on the backing paper, then cut your last image in reverse & stick to the sticky side of your bottom image.
    Sounds long winded but it simpler than it seems & does work
  • Glen Mathers
    7 March 2006 at 19:45
    Rob has done a good demo on this, it looks simple enought.
    http://www.uksignboards.com/viewtopic.php?t=5334
    Glen
  • George Zerbino
    7 March 2006 at 20:30
    Cut the graphics out of some magnetic sheeting, works great for me!
  • Dave Bruce
    7 March 2006 at 20:51
    I have used magnetic material before too, it really is the only way to get the paint on without having the ghost effect on the edges of the finished job.
  • Mike Grant
    7 March 2006 at 23:15
    I use 1.2mm aluminium sheet and cut it out on a table jigsaw. And I charge them for it ! no cheap stencils from me as they do take a while to cut & file the edges. (Don’t want customer sueing me for slicing his pinkie open) 😮
