Home Forums Sign Making Discussions Vinyl what your hints and tips for joining two pieces of vinyl?
  • what your hints and tips for joining two pieces of vinyl?
    Posted by Kenny Ramsey on 21 September 2007 at 18:12
    Hi all
    In the interests of improvement, I thought I’d ask what your hints and tips are for joining to pieces of vinyl.
    I usually cut the stripe/text with a 5mm overlap then just lay it on. It’s not invisible but it doesn’t look bad.
    Am I missing a trick here?
    Kenny 😀
    David Rogers replied 18 years, 2 months ago 2 Members · 2 Replies
  • Alistair Richards
    22 September 2007 at 08:00
    An alternative would be to butt the joins, and then put a thin 5mm strip of vinyl on top. 😀
  • David Rogers
    22 September 2007 at 17:57
    quote Alistair Richards:
    But that can sometimes ‘migrate’ crooked as the vinyl shrinks back (ALL PVC vinyl shrink slightly) & split / raise edges.
    A 2 to 3mm overlap is my normal procedure – with the TOP section being over the bottom if the split is horizontal.
