Home Forums Sign Making Discussions Graphic Design Help what way can i get an eps. into a vector format?
  • what way can i get an eps. into a vector format?
    Posted by del on 4 January 2006 at 23:36
    Hi Peoples 😀
    i have been sent a logo (illistration not photo) from a printer thats a .eps file but i dont think its a vector becouse its all in one layer when i import it into coral draw…
    is there a way to to get it into a vector format? it has 3 layers of colour, but thay all seem to be on the same layer???
    any ideas?
    D
    Dave Bruce replied 19 years, 12 months ago 5 Members · 9 Replies
  • 9 Replies
    4 January 2006 at 23:45
    i correct myself…
    Illustrator read the file correctly.
  • del
    4 January 2006 at 23:46
    Blimy, nice one dave!!! for future ref, how did you do it?
    D 😀 😀 😀 😀 😀 😀 😀 😀
  • Andy Gorman
    5 January 2006 at 00:00
    I’ve just imported it successfully into Corel 9. Use the Postscript Interpreted filter.
    5 January 2006 at 00:02
    Corel didn’t read it well enough.. but I would have just edited the layers to get it right, the vector data was there…
    I opened it in Illustrator CS and saved as PDF.. Opened PDF in Corel 12.. bingo.
    The printers gave u the file in Adobe CS EPS format..
    The other thing.. if you was trying to Import the File into Corel… it defaults as “EPS Ecapusalted Format”, which will just put a ‘thumbnail/lo-res’ placement file in corel… you have to change the filter to ‘Postscript Interperted.’
    Update: Note the butterfly andy. it was all solid purple.. as it is not.
  • Andy Gorman
    5 January 2006 at 00:06
    I’ve got 3 shades of purple Dave. So there! 😛
    5 January 2006 at 00:07
    hm.. corel 12 bug then
  • del
    5 January 2006 at 07:10
    thanks dave, i just tryed it and it works BUT my coral 12 shows it as black also, so as you said must be a bug???
  • Nick Minall
    5 January 2006 at 09:13
    I just tried it with Corel 12 import it as Postscript interpreted and works fine?
  • Dave Bruce
    5 January 2006 at 09:35
    Corel 11 no problems
