Home › Forums › Sign Making Discussions › Vinyl › what vinyl will stick to polyprop?
Posted by Nicola McIntosh on 1 October 2004 at 20:37hi folks 😛
need some advice on a vinyl that will stick to polyprop!! tried it today with 751 did stick, but you can rub your hand over it and it would lift!! 😮
anyone know of a suitable material? 😀 😀
thanks Nik
Nicola McIntosh replied 21 years, 2 months ago 3 Members · 5 Replies -
Hi NikPolyProp is supposed to repell all that wishes to stick to it. Silicons rise to the surface giving it a ‘greasy’ skin. You’ll need a ‘Super’ adhesive on the vinyl (Maybe 3M?) and clean the surface silicons off with isopropanol scrub prior to application of vinyl. Alternatively you could ‘Flame’ the surface (play a flame from a blow lamp over the surface) and burn the silicons off and clean up with isopropanol. Maybe the adhesive could get hold before the silicons come back? That’s an old screen printing trick.
Maybe someone knows of a Super adhesive on vinyl?
Regards Dave -
We use a lot of polyprop and apply a 3m or tessa 4965 tape to it no problem.
I agree that you probably need to use something with a hi tac/ permanent adhesive.
quote popdog:3m or tessa 4965 tape permanent .
thanks dave info appreciated, i had an order to be shipped to bermuda, bulk screenprinted using corriplas ink (which i find is brilliant for polyprop) the rest were just sample prints, using vinyl so i thought 751 (the only one i stock) wiped as you rightly insrtucted before applying vinyl, but it still would not stick too…..good!! 😮
anyway what suppliers stock the above mentioned popdog? 😀
thanks Nik
We have stopped using the Tessa tape but i am sure you can get both from doro tape and or north british tapes.
