Home Forums Sign Making Discussions Vinyl What Vinyl should be used on truck curtains?
  • What Vinyl should be used on truck curtains?
    Posted by Robert Walker on 16 December 2010 at 18:20
    Hi Everyone,
    would you use standard vinyl for this or is there a specialist vinyl for the job?
    also would you remove the curtain for fitting?
    never done curtain sides before
    any advice would be great
    Robert
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Please take a moment to look over our Board Rules.
    Peter Normington replied 14 years, 10 months ago 8 Members · 9 Replies
  • 9 Replies
    16 December 2010 at 18:56
    Hi Robert if you look about 2 posts down "print on curtain sider" there is a lot of information you will find useful.
  • Robert Walker
    16 December 2010 at 18:59
    thanks Lynn
    spotted it minutes after posting,
    17 December 2010 at 21:43
    If you haven’t already read it in the other post Robert you will not be able to use a standard vinyl on a curtain, either something like APA truck vinyl or inks.
    18 December 2010 at 14:27
    havent read the other thread, but to add…
    APA offer a Truck Curtain Vinyl, as do Avery.
    APA being the better priced.
    DO NOT use Banner Vinyl. it is NOT the same thing.
    Truck vinyl is very soft and has an aggressive adhesive. keep this in mind when applying.
    Apply to the curtain whilst on the truck.
    use the tensioning straps to tighten the curtain very tight.
    if you have a spare person. get them to stand "inside the truck" and lean a thick sheet of plywood or MDF aginst the curtain from the inside. it helps application as it stops the curtain flexing inwords when squeegeeing.
    ive heard the Avery truck vinyl "specifies" wet application, but i only do it dry.
    trucks can also be "inked on" using a cheap stencil vinyl.
  • Mo Gillis-Coates
    18 December 2010 at 21:15
    I Just used the APA stuff on a soft skin trailer. Absolutely fab and great stuff to work with. It cuts and weeds really easy. But like rob says. try and get as much tension ibn the side as you can, unfortunately I was on my own, so Iv’e had to re-do a few letters but no major drama.
    I think I paid about £8 a meter including vat, so I cut my text very close together and got as much out of it as I could, I broke up the web address so I could get as much text on the vinyl as I could…. you dont want big blank areas on that stuff, tooo costly!
    Looks great tho, I had to apply outside in -2 conditions so I stuck a big industrial blow heater inside and left it until I could feel the side getting warm….
  • Robert Walker
    18 December 2010 at 22:16
    thanks guys n gals
    much appreciated
    robert
  • Jean Oakley
    4 January 2011 at 14:54
    quote Robert Lambie:
    if you have a spare person. get them to stand “inside the truck” and lean a thick sheet of plywood or MDF aginst the curtain from the inside. it helps application as it stops the curtain flexing inwords when squeegeeing.
    ive heard the Avery truck vinyl “specifies” wet application, but i only do it dry.
    trucks can also be “inked on” using a cheap stencil vinyl.
    i have just ordered 45mt of banner material to cover a stripe apx 7.5 metres long on both sides of a curtain sided wagon. 15mt of white to cover area and two colours to apply over the top. Question do you really think its not a good idea to use on curtain sided wagons and if i were to buy the white apa vinyl could i use the other two coloured banner vinyls over the top of it? many thanks jean
  • Richard Urquhart
    4 January 2011 at 15:23
    NO DONT DO IT
    I would not use banner material on curtain siders it will fail !
    rich
    I have had great success using 2 colours, but have found the APA one a little translucent and may show through what’s behind.
    4 January 2011 at 15:24
    sorry eddited I thought by banner material you meant the actual material, not the vinyl.
    as Rich said.
    get the proper stuff,
