Home Forums Sign Making Discussions Vinyl What type of vinyl will stick (and stay stuck) to rubber?
  • What type of vinyl will stick (and stay stuck) to rubber?
    Posted by Steve Smith on 24 February 2005 at 20:51
    What type of vinyl will stick (and stay stuck) to rubber? I ask because I have a guy who wants to put his company logo on the (welly) boots of his workers. Would I be right in thinking along the lines of Truck vinyl?
    Thanks in advance.
    Steve.
    dazchivers replied 20 years, 8 months ago 11 Members · 19 Replies
  • 19 Replies
    25 February 2005 at 00:48
    some will stick too some extent, none will stay stuck.
    create yourself a stencil from vinyl. stick it to the boots and ink in the stencil and remove. job done….
    very little ink, very little drying time and the most durable print you will get under the circumstances. 😕
  • Steve Smith
    25 February 2005 at 16:07
    Thanks Robert.
    Green wellies, Yellow logo. Will this cause any probs with inking on a design?
    25 February 2005 at 21:23
    quote Robert Lambie:
    and the most durable print you will -?
    just curious rob to what ink you would use? i have been trying to get an ink suitable to print on rubber lorry mud flaps!! 😀
    cheers nik
    25 February 2005 at 21:27
    now there is a thing nik! 😮 :lol1:
    i always thought banner materail like on a truck curtain was a sorta rubber with some sort of fabric between. hence why i thought it would be good on rubber.
    the ink i use is sericol… do you think this be a problem with rubber?
    25 February 2005 at 21:34
    you’ll be using probably vinyl (matt or gloss) ink from sericol….i have tried that and every different ink ed has, but not one took a grip still waiting on feed back from a supplier !! 😛
    thanks anyway 😀
    25 February 2005 at 21:36
    thanks for the feeback nik, but surely it would have much better bite than that of vinyl? 😕
    25 February 2005 at 22:01
    nope the vinyl ink scrapes off when dry!! 😕
    751 won’t stick either and i give the rubber a good clean before hand 😛
    will wait and see!! 😀
  • Cammy – Europoint Display
    28 February 2005 at 21:32
    HI Guys and Gal,
    The reason nothing is sticking is that Rubber wellies are a low energy surface , this stops acids , oils, grime etc from attacking the rubber but also stops adhesive and ink from biting in aswell!! Oracal high tack is a Solvent rubber based adhesive made for such surfaces , you could print a yellow background and cut out the logo for the wellies, worth a try maybe?
    28 February 2005 at 22:03
    quote Cammy:
    thanks cammy for the very informative info 😉 did not know about the high tack 😀
    Nik
  • L J.
    28 February 2005 at 22:28
    I wonder if that would cure a problem i have with a customer who wanted a permanent adhesive vinyl logos that would stick to his food bins, these are as big as pallets, about 4′ high with nice smooth sides that you would think any vinyl would stick to that surface. I think his bins are made of some sort of nylon, if you know what i mean, a bit like a greasy surface.
    I have tried everything i can think off to no avail. I think if i can get hold of a sample of this oracal high tac it might just cure the problem & please my customer before he finds some one else who might already know about this high tac.
    L J
  • Andy Gorman
    1 March 2005 at 00:07
    Hey Rob, what sort of ink do you usually use to write your name on your condoms? That’ll work.
    Sorry. This thread was going so well until I turned up. 😳
  • Paul Rollason
    1 March 2005 at 09:25
    We do a lot of work for yacht crews you know boat names, sail covers, t-shirts, jackets etc
    Never thought of their wellies
    My god I can see a whole new market opening up in front of me.
    Paul R(Mackerelbus design)
  • Steve Broughton
    1 March 2005 at 10:32
    this blokes look quite good
    :lol1:
  • John Singh
    1 March 2005 at 15:29
    quote :
    I wondered why it was so difficult to walk in those things
    Your feet seem to drag 😀
    Nice one Steve:
    Don’t they want the printing on tuther side? 😀
    1 March 2005 at 20:47
    lj1600 , Those bins are likely to be HDPE ( High Density Polyethylene) and yes thats exactly what Oracal High tack was made for — wheelie bins is another common usage , can supply samples if you give you know who a call…
    2 March 2005 at 20:23
    ed done a test with a few inks so nylobag stuck like @~”* 😛
    i know it’s for textiles but it worked!! 😀 😀
    i’m going to try the vinyl cammy mentioned as well though 😛
    Nik
  • Dave Bruce
    2 March 2005 at 22:24
    I used Oracal 751 on my wheelie bin for a show I did and it is still there 8 months later.
    I also put Nikolite on to stone(Granite), been there 3 years, no problem
  • Dave Bruce
    2 March 2005 at 22:26
    What about the tyre paint, usually white but I am sure some custom car shop will have other colours, just a thought.
  • dazchivers
    20 April 2005 at 18:30
    Hands up time, my first post!!
    Just an inquiry if anyone knows of a suitable vinyl for application onto an inflatable rib/boat with a rubber substrate. The inflatable will need to be deflated with the least amount of wear/damage to the signage.
    My initial thought is some type of high tack banner vinyl.
    Any thoughts?
    Any help or advice greatly appreciated
