Home Forums Sign Making Discussions General Sign Topics what type of material do you use for cutting on?
  • what type of material do you use for cutting on?
    Posted by Simon Polakof on 4 September 2008 at 15:49
    I’ve seen a post before cutting boards and according to it most of you out there use a mirror board. But I saw that Rob used another board for cutting a applying the application tape. So I was wondering what all you that don’t use mirror boards use?
    We have an mdf board covered with special cutting carpets, they are old and we need to replace them. But before we invest in such expensive carpets I was thinking of checking out what you all used.
    mod-edit please post in the correct forum
    this has now been moved
    Adrian Yeo replied 17 years, 3 months ago 6 Members · 9 Replies
  • 9 Replies
  • Steve McAdie
    4 September 2008 at 22:28
    I use a small cutting mat for small stuff, also I use an old mirror to cut on as this doesn’t score but goes through blades pretty quickly and I also use my foam-board off cuts but after a few cuts the grooves can start to make the blade wander then I just turn it over and use the other side.
  • David Rogers
    4 September 2008 at 22:36
    8’x4′ sheets of 3mm polypropylene.
    Cheap (£25 a sheet) & virtually indestructible.
    Been using mine for four years and it’s probably slightly overdue for replacement, that’s about 3 years, 11 months, 3 weeks and 4 days longer than a sheet of foamed PVC…and it doesn’t kill blades.
    It’s also non-stick & non-static.
  • Steve McAdie
    5 September 2008 at 08:51
    I think the cutting mats are made from polypropylene but they charge a whole lot more than £25 for them the only difference is probably the mats are printed with a grid on them (which I never use anyway). They are described as self healing. Thanks for the tip Dave think I will get a sheet of that in.
  • Adrian Yeo
    6 September 2008 at 06:44
    quote David Rogers:
    Ohh Bugger!!
    Just bought an A0 size matt from hexis about a two weeks ago :you:
    Dont suppose you have a supplier contact for next time? Done a google but not much use so far.
    Adrian
  • Luca Cabano
    6 September 2008 at 13:40
    i could do with some of that! where do you get it from?
  • David Rogers
    6 September 2008 at 19:00
    I get mine from my local Stockline Plastics, but I’m sure many of the more ‘industrial’ plastics suppliers will do it.
    And it’s not the same as polyethylene…
    did a web search for an online supplier.
    prices not too bad either.
    http://www.directplasticsonline.co.uk/home.php?cat=3844
  • Jamie Kimp
    7 September 2008 at 07:15
    I use an MDF bench top with clear acrylic or thick PVC sheet on top to cut on. It’s not as good as a large cutting mat but the surface is large and flat
  • Brian Little
    7 September 2008 at 08:20
    i use a nice piece of toughened glass . Ive heard it said that it blunts blades rather quickly but i dont find that . Nice and easy to clean
  • Adrian Yeo
    8 September 2008 at 06:03
    Cheers for the link David, Cheap as chips!!
