Home Forums Software Discussions Corel Software What to learn first
  • What to learn first
    Posted by MattS Dawson on 3 August 2009 at 12:11
    Hello
    Right, I have a demo of Corel X4 installed, I have a Creation Pcut with winpcsign which is great for doing basic text and shapes but if I want to try anything a little bit more complex or make a basic image ‘cutable’ then I am at a bit of a loss, hence the want/need to start using Corel
    Is it the power trace function I need to learn first to make an image in to a vector that I can then cut?
    I am quite good at figuring things out I just wanted a shove in the right direction.
    Also if there are any ‘essentials’ that I should learn in Corel I would appreciate a point in the right direction there as well.
    Sorry for the really newbie ish question, we all had to start somewhere though 😳
    Many thanks
    Matt
    Tim Hobbs replied 16 years, 5 months ago 1 Member · 1 Reply
  • 1 Reply
  • Tim Hobbs
    3 August 2009 at 13:45
    Hi Matt
    To be honest I would get into node editing first and foremost, IE using your bezier tool to draw and your node editing tool to tweak.
    I find that, although the trace bitmap feature is very clever, that in most cases I completely redraw the logo as a vector.
    Indeed if all I am doing is to cut out a bitmap I will often trace the outline and covert to a cutline rather than redraw the whole thing.
    If in doubt give post an example of the kind of thing that you want to do and I’d be happy to take a look.
    Tim
