Home Forums Sign Making Discussions General Sign Topics what takes glue off of banner material ?
  • what takes glue off of banner material ?
    Posted by Graeme Speirs on 18 February 2005 at 21:34
    hi guys a client is looking to re use a couple of banners, ie they are peeling off the banner material (451) and hoping to re use the banner. out of interest i wondered whats best to take of the previous glue/residue left behind?
    cheers in advance.
    Shane Drew replied 20 years, 10 months ago 10 Members · 13 Replies
  • 13 Replies
    18 February 2005 at 21:39
    you can use glue and tar remover, but to be honest, banners are so cheap to by its hardly worth the effort involved, and unless really desparate., I would supply a new banner.
    18 February 2005 at 21:53
    I use citrus based cleaners. work a treat and still leave my hands lovely and soft 😳
  • Roy Roffey
    18 February 2005 at 22:03
    i use white spirit – i leave it soaking in for a while then remove
    another tip??
    best wishes
  • Bill Dewison
    18 February 2005 at 22:05
    I do the same as Roffs, soak a rag in white spirits, splash it about the banner. I leave it for about 5 minutes, then pull the banner taut and use a windscreen ice scraper to scrape the glue residue off. Wipe over with the rag to get off any stubborn bits and wash the banner with soap & water.
    Cheers, Dewi
    18 February 2005 at 22:12
    i do the exact same as dewi but use thinnners seems quicker to me!! 😀
  • John Singh
    18 February 2005 at 22:13
    Same as Dewi and Roff
    Make sure you open the windows though :vomit:
    John 😀
  • Bill Dewison
    18 February 2005 at 22:14
    If you open the windows though John, you lose the ‘happy’ feeling you get that carries you through the day *hair*
    Cheers, Dewi
  • John Singh
    18 February 2005 at 22:18
    You don’t need white spirits for that when you’ve got *drink* in stock 😀
  • Kevin.Beck
    19 February 2005 at 08:23
    I use glue remover from hexis.
    I once used screen cleaner and melted the banner, so becareful what solvent you use.
    But like others have mentioned, banners are really cheap, so it an`t worth the effort.
    If you are cleaning a banner up, make sure you get paid for it, as it does take time and also to cover the chemicals/rags used.
    I try to get them to clean it off. If they want me to clean it off they have to pay. Time is money.
    a 10ft x 2ft banner is only £15 max, I`d want that for cleaning one off…..
  • Graeme Speirs
    19 February 2005 at 10:20
    thanks guys, client is cleaning up the banner, I just want to get it 100% upon return I agree re doing a banner is the shout, however its a pretty good rate even for me to re letter the banner as there could be a fair few.
    many thanks for all the advice.
    19 February 2005 at 10:38
    i agree with peter here, “depending on the size” it is cheaper to buy a new one than clean masses of glue. i know what you mean by saving client a few bob but…. lets say the banner is about 10 foot by 3 foot. cost roughly £11 or £12 & its gauranteed next day.. lets you get on with other stuff…
    take same banner covered in glue… could take you hours to clean and still looks mingin.. 😕
    take the hours you spend cleaning it… your hourly rate will exceed the £12 spent on new one…
    you dont have to make a markup on the new banner, just use the low cost of buying one more convenient for yourself.
    on the other hand if its huge and only parts have glue…
    the above tips are good…
    something i do though that works a treat…
    get some tar and glue remover… from carvalet supplers and the like…
    create a puddle of the stuff over the glue area… leave for3-5 minutes and then using a “bare” stanely drag it firmly towards yourself on the banner and the glue comes right off in one go…
    you have to have a bag of some sort to keep dropping all the glue gunk into but works very well.
    the problem with removing glue from a baner is normaly the chemicals break the glue down, but when wiping it just moves the glue around and it catches in the banner grain making it look dirty & slightly tacky.
  • Ian Higgins
    19 February 2005 at 12:25
    Hi ,
    We used to use tar remover … but as others have said banners are so cheap now we tell all customers it is not cost effective to clean them.. If they do it we will re letter them, but they never clean them properly.
    We now say that due to new COSHH regulations we can not use chemicals on site.. that tends to work!!
    Ian
    19 February 2005 at 12:32
    Had a guy drop a banner of the other day, and left it in my factory. End of the day, the factory stunk of fuel. I assumed my car was leaking petrol so spent forever trying to find the leak.
    Was not until I unrolled the banner and found that the whole thing had been cleaned with fuel 😮 Glad I don’t smoke.
    The fuel wrecked the banner so I refused to sign it. Made him buy a new one. 🙄 I found out later he developed a nasty rash on his hands… wonder why 😕
