Home Forums Sign Making Discussions Graphic Design Help what software do i need to curve lettering?
  • what software do i need to curve lettering?
    Posted by wiredforgames on 7 May 2005 at 10:15
    Hi I have got a wheel cover to do on a 4×4 trouble is i don’t know where to start the workable radius is 22" its for a barber shop he wants "SHEARERS" curving around the top and "BARBER SHOP" curving round the bottom and something to do with a barber shop in the middle, I have FlexiSign and Sign go any pointers in the right direction would be fantastic( ie what tools to use and is there any other special software that i might need).
    Yours Justin..
    Gordon Forbes replied 20 years, 6 months ago 4 Members · 18 Replies
  • 18 Replies
  • Jayne Marsh
    7 May 2005 at 10:38
    You can use youre text on a curve tool, in design central put in your radius and type in the text, in design central there are buttons that do the text “on” , “above” or “below” the line etc, have a play around until you get it how you want , you can also create a circle the size of the cover to place your design in for scale,
    hope this helps
    Jeff
  • wiredforgames
    7 May 2005 at 10:52
    Hi thanks for the reply Jem is this in Flexi as i recall you using that software
    Cheers Justin..
  • wiredforgames
    7 May 2005 at 10:53
    oh sorry jeff i mean
  • Jayne Marsh
    7 May 2005 at 15:23
    Yes that’s in Flexi, Jeff (my hubby ) does Flexi training.
  • wiredforgames
    10 May 2005 at 09:47
    Hi jeff iam having problems with this 😳 i cant find where to put the radius in design central it seems to be in degrees I know its me doing something wrong but i don’t know what.
    Justin…
    P.s. how much do you charge for lessons? (I think i need em) 😀
    10 May 2005 at 09:58
    Dont Know about flexy, but cant you just draw a circle, and type in the diameter?
  • wiredforgames
    10 May 2005 at 10:38
    Hi thanks for the reply peter i have tried your sugestion but i am unable to find where you type in the diameter (not having much luck am i)
    10 May 2005 at 11:05
    just in caseyou are desparate, here is a 22″ diameter circle
  • Jayne Marsh
    10 May 2005 at 12:17
    Hi Justin,
    If you select text on an arc, you should get “Arc” in design central, look there and put your curser over the first box ( it will say radius when your curser is over it ) the other degrees box will rotate your text on the arc (I think)
  • wiredforgames
    10 May 2005 at 12:49
    Hi Jem i think i may have a different version than you mine is 7.5v5 the first box i hover over says rotation angle..
    Justin..
  • Jayne Marsh
    10 May 2005 at 12:55
    Hang on there I’ll take a look at 7.5 version then
  • Jayne Marsh
    10 May 2005 at 12:59
    When you select text on an arc look at design central and you will see two boxes one on top of the other, one is the radius (top box) underneath is the angle box. Enter your radius in the top box and it should work. To get this in design central you will need to click your mouse onto your work page as though you are about to type your text, it then comes up in design central, hope this helps
  • wiredforgames
    10 May 2005 at 13:07
    Hi Jem thank you i think i have finally got there i was not clicking on the design sheet, so if a put the diameter in there that will get my 22″ text but then should i put this into peters 22″ circle to get the correct curvature?
    Justin..<——Getting there i think:)
  • Jayne Marsh
    10 May 2005 at 13:13
    If it was me I would enter the radius you want (not diameter) and then type your text, you can size it once you’ve typed it, you can also alter the radius after you’ve typed it so have a go because you can always change things after you’ve typed, such as letter spacing, height, positioning. The arc box will be in design central when you select the type.
  • wiredforgames
    10 May 2005 at 13:17
    Yes i have being doing just that jem hopefully the arc feature will follow a circle anyway, I’m gonna cut one and see lol, thanks for all your help Jem very much appreciated..
    Justin 😀
  • wiredforgames
    10 May 2005 at 13:30
    Hi peter just a quickie, you may have left some work on the circle image just in case you want to remove the attachment..
    I don’t know how to PM sorry..
    Justin..
  • wiredforgames
    10 May 2005 at 14:42
    lj
  • Gordon Forbes
    10 May 2005 at 23:04
    Flexi must be doing a bomb in sales !!!
    Goop
