Home Forums Sign Making Discussions General Sign Topics What size rebate would you use between the panels?
  • What size rebate would you use between the panels?
    Posted by David_Evans on 19 June 2008 at 16:23
    I have a 500mm x 9000mm sign to fit which will be in 3 x 3000mm dibond panels in a pantrim frame. What size rebate would you use between the panels?
    Any help much appreciated
    Peter Normington replied 17 years, 6 months ago 3 Members · 3 Replies
  • David Rogers
    19 June 2008 at 18:47
    I never rebate my dibond…what’s the point?
    A strip of ‘spare’ material on the rear to join them together with VHB tape works for me. Then, if flood coated – ensure the vinyl is wrapped ROUND the edge or a small strip is added to conceal any minor gap.
    I’ve only used rebates on acrylic…and really only for lightboxes to stop light from shining through.
  • David_Evans
    19 June 2008 at 18:54
    I see your point Dave don’t really know why i do it! I just like the way it interlocks. Its going to be black dibond so no need to floodcoat. Just need to add some vinyl text and maybe some brushed ali stand offs.
    19 June 2008 at 18:55
    I will second that
    but use spring inserts in the edges to keep the panels together.
