Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters What Settings for Cutting Sandblast Vinyl?
  • What Settings for Cutting Sandblast Vinyl?
    Posted by John Cooper on 13 November 2011 at 12:07
    Hi guys
    I can’t remember the settings for cutting sandblast vinyl with the Graphtec CE5000-60. I recall it requires a 60deg blade.
    Any ideas?
    John Cooper replied 14 years, 1 month ago 2 Members · 2 Replies
    13 November 2011 at 13:09
    untick the enable driver functions
    set the plotter to conditions 5 (or one you don’t use)
    set condition to force 20 ish
    speed to 8
    quality 3
    offset to match the knife
    if you have tangentel mode turn it on for that condition No.
    tangental mode 1
    overcut .3mm
    then test cut and alter the pressure to suit
    for low volume work does not have to be a 60 deg blade just corners may be a little sharper.
    flaming CM2 getting in the way again
  • John Cooper
    13 November 2011 at 13:14
    Thanks Chris
    The only reason we use the ‘enable driver functions’ is so we can ‘Save as’ and give the settings a meaningful name. Angie finds it easier if I setup these setting for the different types of materials we use.
    I can’t remember the last time we used the cutter’s front panel settings. Maybe I’m missing some other functionality and need to acquaint myself with the hardware.
