Home Forums Software Discussions Corel Software What’s the easiest way to edit a font, like this…
  • What’s the easiest way to edit a font, like this…
    Posted by Nick Minnery on 3 April 2013 at 11:55
    Basically, I need to break apart a font into two section (see pic), what would be the simplest way of doing this in Coreldraw?
    Any suggestions are much appreciated,
    Many thanks
    Nick
    Chris Windebank replied 12 years, 9 months ago 7 Members · 10 Replies
  • 10 Replies
    3 April 2013 at 12:04
    Would you be producing it in cut vinyl.
    I don’t use corel, but using illustrator and cutting master, I would add the rectangle for the white cut through, and then in cutting master crop the area that is being cut to minimise waste.
    Cut the Red & Black, then just weed it out?
  • Nick Minnery
    3 April 2013 at 12:09
    quote David Hammond:
    Hi David
    Thanks for that, sounds like a plan. Just not sure I can ‘crop’ a vector image in my cutting software, will give it a go.
    Thanks again!
  • NeilRoss
    3 April 2013 at 12:13
    Probably a few different ways to do it but here’s what I’d do.
    Type up the text
    Ctrl+Q to convert text to curves
    Draw a horizontal box across the text where the gap is
    Select all
    use Back Minus Front function
    Ctrl+K to break curve appart.
    You may lose the lower middle of the B. Select (window) the lower half of the B and use the Combine function to join the two parts.
    Works for me.
    3 April 2013 at 12:19
    Takes less than a minute in Corel.
  • Nick Minnery
    3 April 2013 at 12:25
    Neil, thanks for that. I got up to the ‘Back Minus Front’ function, but wasn’t quite sure what that was??
    Jill, that is VERY easy, thanks very much! I really do need to spend a weekend reading the Coreldraw book, instead of making it up as I go along!
    Thanks everyone 😀
  • NeilRoss
    3 April 2013 at 12:39
    quote Nick Minnery:
    Thanks everyone 😀
    Arrange/Shaping/Back Minus Front
    Normally on the toolbar too when you select more than object. 🙂
  • Harry Cleary
    3 April 2013 at 12:51
    quote Jill Marie Welsh:
    Is that what the Circumcision shortcut in ‘Tools’ is for? 😮
    3 April 2013 at 12:54
    I was going to use my fave word but got inspired once I thought about snipping things.
    I’m self taught "idiot mode" in Corel, I learn by making mistakes as I go along.
  • Noel Kearney
    3 April 2013 at 13:13
    http://coreldrawtips.com is a great site for tutorials
  • Chris Windebank
    3 April 2013 at 13:59
    or use the smart fill tool on left hand side corel X4 onwards
    Type word, add rectangle and place in position then just use smart fill to click where you want the fills
