Home Forums Sign Making Discussions General Sign Topics What’s it called?
  • What’s it called?
    Posted by Martin C on 4 July 2003 at 11:05
    I need some very flexible thin, card like plastic sheet to produce posters to stick on the side of an A-Board. 3mm Foamex is too thick as they will occasionally be used behind the magnetic Poster holder on the other side. A Vinyl print will be too floppy.
    Anyone know who supplies it and what it’s called?
    Graham.Scanlan replied 22 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Alan
    4 July 2003 at 11:33
    Hi Martin,
    I use 1mm Foamex for that type of thing.
    Alan
    4 July 2003 at 11:35
    try “HIPS” PLASTIC.. VERY CHEAP.. 1mm thick i think and nice gloss face..
    only 36″ x 24″ though….
    hope this helps
    try AMARI Plastics
  • Martin C
    4 July 2003 at 11:38
    Thanks……..
    I wasn’t aware that you could get 1mm Foamex….should check my supplier catalogues! 😳 😳
  • Graham.Scanlan
    4 July 2003 at 19:03
    you could even try genotherm,
    this is a white or clear pvc sheet,
    it comes in the following,
    140 micron, 240 micron, 480 micron , 700 micron, and 1000 micron
    1000 mic = 1mm
    480 mic = 1/2 mm etc
    softer than hips
  • Mark Horley
    4 July 2003 at 21:24
    whats the sheet size and who stocks it nationally
  • Rebecca
    4 July 2003 at 23:26
    A&P Display do a high impact polystyrene ranging from 250 micron to 3000 micron in sheet sizes 915 x 610 and 1372 x 660
    Rebecca
  • Graham.Scanlan
    5 July 2003 at 21:34
    same for the pvc sheets
    (big in the safety sign market)
    A&P also Europoint, etc
    sheet sizes
    635 x 914, 1422 x 914, 1040 x 1550 , 1220 x 915
