Home Forums Software Discussions Flexi Sign Software what profile can i use with signwizard Ucut & flexisign?
  • what profile can i use with signwizard Ucut & flexisign?
    Posted by John Cornfield on 24 August 2005 at 19:31
    piced up a ceap cutter for a new sight andwould like to run it with flexi.
    no profile for the cutter available but the guys at signwizard suggestedit would work with another machines profile.
    anybody using on eof these machines and using another machine profile to drive it?
    Paul Leicester replied 20 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Nigel Pugh
    24 August 2005 at 20:58
    What’s the language HPGL ??
    Nigel
  • John Cornfield
    24 August 2005 at 21:05
    I Think so!
  • Nigel Pugh
    25 August 2005 at 08:17
    I know that SignPal & Roland run pretty much on the same hpgl and drivers for either machine would generally work.
    Try any of the two, also if there generic hpgl drivers in the driver list then these may work.
    Nigel
  • John Cornfield
    25 August 2005 at 08:53
    Will give it a try.
  • Steve Dawson
    25 August 2005 at 10:00
    if its the P-cut (serial) (touch pad to the right top , light blue pads) , then i’m running corel draw signcut , very pleased…..
    sd
  • Adder
    25 August 2005 at 18:45
    If it’s a UCUT try the link below, maybe a little help.
    Keith
    http://ucut.net/english/prod_view.php?id=6&fla=6&exp=1
  • John Cornfield
    25 August 2005 at 19:55
    thanks adder
    i have sent them an email.
  • Paul Leicester
    27 August 2005 at 10:02
    Hi folks
    We have been asked this question alot recently and always for Flexisign (which we don’t have to test).
    I’ve used these drivers successfully with the UCut range of machines (not in Flexi) Houston DMPL, Generic DMPL, PCut, Copam and DingTec.
    The manufacturer doesn’t have an association with Flexi so there isn’t a dedicated driver in their range to my knowledge.
    All these cutters in the UK are supplied with a free copy of SignCut STD which has the correct drivers and of course there is the option (£200.00) to upgrade to SignBlazer Pro which also has the correct drivers implemented.
    Hope this helps – Regards Paul
    Signwizard UK Ltd
    quote John Cornfield:
