Home Forums Sign Making Discussions CNC Router and Engraving what method do you use to spray pvc?
  • what method do you use to spray pvc?
    Posted by Martin Kennedy on 3 September 2007 at 18:22
    Hi All
    We’ve been spraying our router cut foam PVC letters for over a year now and find that we have to sand / prime / sand / prime / top coat the letters to get a good result. Main issue is the ‘open’ cells of the foam PVC and the paint soaking into the exposed edges which makes the finish poor.
    We use our method and a 2 pack process paint as our spray-painter comes from an auto body repair background.
    Is there another way to carry out this operation or a spray that will close the cells of the foam to give a high quality result?
    I look forward to being educated (again) by all you clever guys and gals…
    Martin :lol1:
    Ian Johnston replied 18 years, 3 months ago 3 Members · 3 Replies
  • Richard Urquhart
    3 September 2007 at 18:54
    how about a coat of primer then before you sand the primer apply some 2k stopper then sand the both and top coat
    Rich
  • Martin Kennedy
    4 September 2007 at 10:23
    Tnanks Rich
    We’ll try that (will try anything to see if it works)
    Anybody else got suggestions on this?
    Martin
  • Ian Johnston
    4 September 2007 at 12:09
    we use evostik 3019 or any pvc pipe adhesive that you can get in a builders merchants, rub it into the core and it seals it instantly, quick sand and a light topcoat primer and that you, beware , you’ll get that high on the fumes all the staff will be fighting to get to do it :lol1: :lol1:
