Home Forums Sign Making Discussions Vehicle Wrapping What material should I use?
  • What material should I use?
    Posted by Craig Bond on 14 October 2015 at 13:32
    Hi everyone. Its been a long time since I posted on here, its good to still see familiar faces.
    I’ve have been asked to put a full colour picture on the side panel of a Hyundi iload van, very deep panels!! I thought the old Spinter panels were deep! I cant upload a picture as it exceeds the file size.
    What material would you recommend? Would you use an air release film?
    Any help would be greatly appreciated.
    Craig
    Craig Bond replied 10 years, 1 month ago 4 Members · 6 Replies
  • Unknown Member
    14 October 2015 at 14:19
    I would go for a 3m IJ380 if you want to make sure those recessed don’t cause you an issue.
    I presuming this is a digital printed wrap
  • Craig Bond
    14 October 2015 at 15:31
    Thanks James
    Oh yes it’s a full printed wrap. It’s quite a big job for me as I tend to only do part wraps. I normally use Metamark MD7 but I find it to be very ‘grabby’ I shall google the 3M film. Many thanks
  • Jon Marshall
    14 October 2015 at 15:35
    IJ380. Bear in mind it is not an easy film to fi,t so if you’ve not fitted it before have a practice first.
  • Craig Bond
    14 October 2015 at 15:37
    Thanks Jon
    I shall bear that in mind. I take it that it is grabby also?
  • Simon Worrall
    14 October 2015 at 19:34
    Definitely 3M IJ380.
    If the recesses are very deep you might consider some 3M primer in the corners as well, as the adhesive will get very thin there
    Simon.
  • Craig Bond
    14 October 2015 at 20:18
    Thanks Simon
