Home › Forums › Printing Discussions › General Printing Topics › What material for "DON’T PARK HERE" stickers?
Posted by Graeme Speirs on 2 October 2006 at 11:35can anyone advise as to whats the best vinyl to use? you know the stuff that when you try to remove comes away in tiny pieces?
have a customer who wants 1000 A4 stickers so help would be appreciated.
graemeDavid Rowland replied 19 years, 3 months ago 6 Members · 10 Replies -
its not vinyl its ahesive backed paper. cheaper the better as it "very" short term.
i know grafityp do a nice silk finished adhesive backed paper that is very hard to tear because i was looking at some swatches at signuk this year. so i would "guess" they will also offer a cheaper alternative too…
another one would be europoint display, if they dont do it direct ide imagine their parent company "Paper Co" will do it.
sory I meant to add this is for digital printing?
called europoint and they dont stock the product I need for digital printing?
any ideas?
spandex do it but expensive for that job it can be edge printed but solvent ?.
Hi All,
The material is called crack-back, basically its self adhesive paper. Any paper merchants should stock it, ie. Robert Hornes & Mcnaughtons. You should be able to print onto it.Cheers John
I thought Crack-Back is the material with the backing paper slit for easy removal when cut into stickers.
I think the material wanted is often known as Ultra-Destruct which is a thin brittle vinyl that breaks up when you try to remove it.
yep.. crack back is easy to remove the backing with a slit…
solvent inkjet is a solvent printer, not sure I would print onto paper with it and that sounds like what u want, paper-type stickers that break.
I am now looking at A4 full size paper labels which can be bought off flea bay for £4 per 100 pack, then print onto them with a good desktop printer.
yep.. good.. but watch out for water based ink where the first bit of rain will smear the ink.
