Activity Feed › Forums › Sign Making Discussions › Neon, LED, Lighting › what material can i use to advertise outside?
Posted by del on September 26, 2005 at 10:35 pmHay! 😀
I need to make a sinh that can be proped up against a house when a builder is working inside. I realy dont want to use wood and paint it so is there anything els i could use? Preaty much a pannel that is ready just for lettering?
DDavid Rowland replied 18 years, 9 months ago 9 Members · 26 Replies -
Try foamex or rigid pvc (10mm)
https://www.uksignboards.com/viewtopic.p … 426#106426
Or correx 10MM fluted
Peter -
I use fluted board, like estate agents use. If you get the 10mm thick stuff, it is as rigid as timber. About 20 squids for an 8′ x 4′. Most sheet material suppliers should stock it. Amari, Europoint etc. It is called Correx, but there are probably other names for it as well.
i would use correx..you would only need 6mm, if they are to tie to railings or fences 😀
Yep, its just a free standing board to go against a house or a fence, thanx Nic!
i take it these boards dont need painting? just slap the ol’ letters no , sorted?
Correx (we call it Coroplast) is the way to go.
The thinner stuff accepts wire step stakes.
You can also hammer grommets into it to fasten it with wire-ties.
Comes in colors, is cheap, and vinyl sticks to it great.
But just because it’s cheap doesn’t mean you have to charge too cheap.
Love….Jill -
I think the 10mm only comes in white, but yes, it is ready to apply graphics to. The thinner stuff comes in a small range of colours. You can always flood coat it with vinyl if you want to change the colour. Rob did a demo on this a while back. It’s in the demo section, I reckon.
you will find these in members section mate… ide advise clicking on some just finding out what each are. if not to purchase them at least to give you an idea of a price to haggle other suppliers 😉
correx varies thicknesses to the group
https://www.uksignboards.com/viewtopic.php?t=9415correx 10mm like has been said…
https://www.uksignboards.com/viewtopic.php?t=9416cheap unbranded foamex prices, “dont go thinner than 5mm”
https://www.uksignboards.com/viewtopic.php?t=9421 -
Rob, the foam-x link you’ve given is for the display board type stuff, not foamex, I think.
Do you two take turns on the computer, or do you have seperate ones? It’s like bleedin’ tweedle dum and tweedle dee with you. I reckon Peter puts on a wig and pretends to be Lynn and you are really one person. I’ve never seen the two of you together…….where was Lynn at the sign show? I expect to see you BOTH there next year.
thats a bit cheeky Andy, how can you think that I am a transvestite
Lynn -
Peter -
I dunno Peter, but I’m getting mighty worried about you always going on about the correct name for PVC products!
Latex is really much better Andy,
CU
peter
