Home Forums Sign Making Discussions Vinyl what looks like watermarks around vinyl lettering?
  • what looks like watermarks around vinyl lettering?
    Posted by Jon Fields on 13 April 2005 at 21:03
    Hi all
    i have reverse applied some vinyl text onto acrylic clear sheets for a customer internal display..no probs..the customer decided to have a
    a blanket of coloured vinyl behind to make the lettering stand out..
    i decided to apply wet because of the size..since it has dried i have noticed
    what looks like watermarks around the lettering..is this due to the type of vinyl used (polymeric) or the way it was applied..?
    Jon 😕
    Jon Fields replied 20 years, 8 months ago 2 Members · 4 Replies
  • Nigel Fraser
    13 April 2005 at 21:20
    Jon, do you mean you applied the flood coat over the top of your text ?
    If so, you will always get a thin silvery line around the text because of the thickness of the vinyl your text is made from. I’ve had customers comment that this actually makes a nice effect ! Theres no way round it anyway 😉
    Nigel
  • Jon Fields
    13 April 2005 at 21:29
    Thanks for your reply..
    yes that’s what has happened..but also some areas of the vinyl have “patches” on them as well..so im a bit puzzled. I dont suppose there
    is a problem fitting wet like this is there?
    Jon
  • Nigel Fraser
    13 April 2005 at 21:33
    No problem as long as the vinyl doesn’t have a water based adhesive – most don’t. You may find you just have to squeegie a bit harder to remove more water (specially round the text which traps the water in the gaps at the edges). It can take a few weeks for all the water to dry so dont panic yet !
    Nigel
  • Jon Fields
    13 April 2005 at 21:38
    Thanks Nigel
    I ll keep checking it.Like you say..Hopefully it will go away.
    Jon
