what layout can i use for a dedicated print & fnishing r
Hey guys,
I am in the process of getting the plans together for a dedicated print and finishing room I probably mentioned late last year before we moved into our new place.
The room I have to work with is 5 metres wide by 15 metres long. I will be building a mezzanine so it will be double story.
I would like a few opinions.
In the future if we do get a 2.6 metre printer how do you load the media? Do you need a forklift etc?
What flooring should I use to reduce any static and make cleaning easy?
What lighting is best used to see fairly accurate colour? Mix and match tubes? Run both cool and warm off different circuits so I can check both?
What kind of heating system and humidity control systems do you currently employ?
That’s about it for now.
Jason
