Home Forums Sign Making Discussions Vinyl what is the best vinyl for applying to an lcd protector?
  • what is the best vinyl for applying to an lcd protector?
    Posted by scraggy on 7 January 2007 at 22:37
    Hi all
    I know this is a bit of a strange one but I wonder if you can help
    I want to cut some screen protectors for some small lcd displays I have (i can’t seem to find any for sale) so I was wondering if you had any idea of a fairly thick but easy to peel off vinyl that I could use and that would cut fairly well.
    I had thought about window cling but don’t think that would have enough tack.
    Any advice would be much apreciated
    Scraggy
    John Childs replied 18 years, 10 months ago 6 Members · 6 Replies
    7 January 2007 at 23:23
    not sure if this is what your after but what about paint mask vinyl? its cheap as chips and has a low tack. i say low, i mean lower than regular vinyl.
  • George Kern
    8 January 2007 at 05:14
    I know 3M has the paint protection vinyl but its not too cheap.
  • keirsmart
    8 January 2007 at 12:02
    I would have thought that any short life monomeric removable vinyl would do the trick. This is usually between 70-100 microns thick and the adhesive is ~25% normal strength and is designed for easy removal for up to 2 years.
    This is available in many colours and in clear if you want them to see through. Any vinyl supplier can supply this.
  • Dale Hughes
    8 January 2007 at 12:14
    what about using transparent static cling vinyl without adhesive i will send you a link to a sight you can get it from
    Dale
  • scraggy
    8 January 2007 at 13:33
    Thanks for the help
    I spoke to Victory & Metamark today and they are going to send a few samples out, its the first time I have dealt with either and I must say they were both incredibly helpful.
  • John Childs
    8 January 2007 at 14:55
    Or you could use the proper tool for the job. 😀
    Go to http://www.expansys.co.uk and do a search for writeshield.
    Not particularly cheap, but writeshield is the best that I have come across. I’ve got it on all my phones, pdas and satnavs.
