Home Forums Sign Making Discussions Traditional what is the best mix of 1shot paint to cover properly?
  • what is the best mix of 1shot paint to cover properly?
    Posted by ianK on 21 January 2008 at 12:25
    hi all as I’ve just started learning doing signs well been doing them about year on and off what is the best mix of 1shot paint to cover properly ? I’ve got one shot reducer just wanted to know how you would mix it for example put so much reducer into the tin?
    cheers again for the help
    Ian 😀
    Neil Davey replied 17 years, 11 months ago 1 Member · 1 Reply
  • 1 Reply
  • Neil Davey
    21 January 2008 at 12:51
    Hi Ian, I don’t know whether you have cold or hot weather reducer but this time of year obviously I would use cold.
    I only use a small amount which I pour into the paint from the screw cap.
    Again, I only use this when I’m lettering, if you are coating up a signboard I wouldn’t use any and apply the paint with a foam roller.
    Hope this helps
