Home Forums Sign Making Discussions Neon, LED, Lighting What is the best method to hide a join in lightbox?
  • What is the best method to hide a join in lightbox?
    Posted by f1graphics on 1 September 2005 at 12:15
    Hi All
    We have our first lightbox sign to do.
    What is the best method to hide the join on two acrylic sheet butted together?
    Help
    Darren
    Martin Pearson replied 20 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
    1 September 2005 at 12:18
    I dovetail the join and it is the least likely to be seen. or you could bridge it with a clear joiner, but it tends to look a bit untidy.
  • f1graphics
    1 September 2005 at 12:21
    Can you bridge the join with the opal acrylic as clear may show the light through at the join to much???
    Also what glue would you use??
    1 September 2005 at 12:25
    quote f1graphics:
    If you can get an opal bridge, sure, but an opal bridge will sho up darker, as it is effectively a double layer of opal…. if you get my drift
    1 September 2005 at 12:26
    you can buy (here anyway) crystal clear acrylic ‘welding glue’. Any acrylic supplier should be able to point you in the right direction
  • Guy Burt-Davies
    1 September 2005 at 13:00
    Shane’s first response is probably the best way to go, dovetail or lap joint the panels, any bridging piece – even a clear one – could show through the opal acrylic.
  • chris@lazerpics
    1 September 2005 at 13:51
    Try Westward Plastics 0117 935 8058, tensol is what we use for acrylic
  • Andy Gorman
    1 September 2005 at 14:10
    Are you supplying the lightbox as well? If so, you should be able to buy it with the panels already made and fitted, dovetailed and with a joining strip on the back. That’s what I do.
    1 September 2005 at 16:56
    As Andy has said if you are buying the box in just get the panels supplied as well and ask for they to be overlapped, you can do it yourself with a hand router and get pretty good results but it’s far easier to buy the panels along with the box.
