Home Forums Sign Making Discussions CNC Router and Engraving what File Format do i need for routing?
  • what File Format do i need for routing?
    Posted by Robert Berwick on 1 June 2006 at 16:35
    Hello,
    This is my first dip of the toe into the router forum.
    We’ve been asked to produce a sign which has two different colours overlapping each other.
    I would like to make the sign out of Perspex (or some such). I want to relieve the pieces so that when they overlap they form one flat surface. (So starting with 10mm perspex I want to take 5mm off of each piece in the overlapping areas).
    I have modelled exactly what I want in a CAD program, and all I really want to know is whether a trade supplier will be able to use the files that I’ve produced. If CAD files are what are used in the routing world, what format will I need to save them as?
    Many thanks
    Robert
    David Rowland replied 19 years, 6 months ago 5 Members · 6 Replies
  • Martin Kennedy
    2 June 2006 at 13:11
    Robert
    A quick reply –
    Save the files as .dxf files. Your trade router service will convert these to .plt (PLOT) files for use on the router.
    Martin
  • Robert Berwick
    2 June 2006 at 15:14
    Martin,
    Thanks, I just needed to know that I could output my file as something someone else would be able to use. DXF is no problem.
    Robert
  • Fran Hollywood
    2 June 2006 at 18:56
    Robert,
    if you use Corel you save to PLT, or open a DXF and save to PLT.
    Our CNC machine reads DXF & PLT but sometimes it finds DXF’s funny and we convert to PLT in corel.
    2 June 2006 at 21:47
    yeah.. we just stopped using corel PLT to Toolpath and now using DXF I think… just changed as issues.
    You will get some problems with file transfer, some industry Cad CNC machines require correct DXF or they end up retracing the images, possibly down to their skills and staff. But I would allow a few days for error… get ur cad files off for trial, dont leave to last minute.
    2 June 2006 at 22:00
    ive had a cnc router now for about 7 years maybe… "im still no expert"
    9/10 times i export as plt from signlab. i find when exporting files for engraving small text in any other format, the letter "curves" appear a bit like a hexagon.
    2 June 2006 at 23:23
    Yeah.. we had AXYS down to fine tune our setup… its pretty good now im pleased to say… the PLT > Toolpath in our case isn’t perfect, could be Corel as u do get path errors… but Bruce started mucking about with transfering DXF on the same file and AXYS I believe backed him up on that.
