Home Forums Sign Making Discussions Vinyl what can i use to weight the bottom of banners?
  • what can i use to weight the bottom of banners?
    Posted by John Stevenson on 15 June 2007 at 07:18
    We’ve been asked for some vinyl banners with weights in the bottom hem.
    What do you use for weights?
    Client has described the requirement as "Lead Weights" but I don’t know if that’s right?
    tonygoodall replied 18 years, 5 months ago 10 Members · 13 Replies
  • 13 Replies
    15 June 2007 at 07:24
    John,
    we have used scaffold poles in the past, Not sure where you would get lead from nowadays, its pretty much been replaces by modern alternatives,
  • Nick Minall
    15 June 2007 at 07:40
    Just go to your local metal/fabrication shop and get some steel bars?
  • Bill McMurtry
    15 June 2007 at 07:44
    Fill the hem with Lead Shot?
  • Graeme Harrold
    16 June 2007 at 20:53
    quote Bill McMurtry:
    Expensive way of doing it, but very flexible………..one whiff and the local scuba divers will be nicking it!!!! £3-5 per pound 😛
  • John Childs
    16 June 2007 at 21:30
    The same weights as used in curtain making?
    http://www.copes.co.uk/products.asp?partno=1202
  • John Stevenson
    17 June 2007 at 08:01
    any more ideas?
  • Bill McMurtry
    17 June 2007 at 09:33
    Solder sticks or coil – might be too expensive though? Roofing lead sheet cut into thin strips? Pour sand or gravel into the hem?
    17 June 2007 at 11:24
    just rods or anything i can find and sew them in hidden.
  • John Stevenson
    17 June 2007 at 11:29
    OK Thanks everybody
    so, there’s nothing special, just whatever heavy thing is suitable
  • Jeremy Howes
    17 June 2007 at 22:41
    Steel chain
    Jeremy
  • George Kern
    18 June 2007 at 03:05
    you could always take PVC pipe and get a good cement mixture cap off the one end, pour it in let it settle, then cap the other end off.3
  • John Stevenson
    22 June 2007 at 05:00
    Thought I should let you know what I did about this in the end.
    I bought some 12mm dia steel tube from B&Q.
    Cut it to 1m lengths so that the 3m wide banner could be folded.
  • tonygoodall
    22 June 2007 at 09:11
    Hi Mate
    We manufacture roller blinds, we use a high density pvc weight that comes in long strips, just cut down with hacksaw and bobs your uncle.
    If you need any give me a ring 07876 568628
    Tony
