Home Forums Sign Making Discussions Neon, LED, Lighting what can i use to suspend a dibond panel between poles?
  • what can i use to suspend a dibond panel between poles?
    Posted by Nick Dowell on 5 September 2007 at 11:21
    Hi All,
    We are looking to "suspend" a diabond panel between 2 ali poles (our standard flag poles) So we need some clips that go round the post and then clamp onto the flat panel-probably with something that goes through a hole in the panel as it will be quite large?
    I no its quite vague but any help or direction would be much appreicated 🙂
    many thanks
    Nick
    Warren Beard replied 18 years, 3 months ago 3 Members · 4 Replies
    5 September 2007 at 11:25
    could you not glue channel onto the back of the dibond and use post clips to fit into it ? the same as most street furniture ? or is this not possible ?
  • Nick Dowell
    5 September 2007 at 11:30
    HI,
    No they would rather have the posts either side of the panel, I have seen similar type signs somewhere…but typically I cant recall where when i need it!!
    5 September 2007 at 11:38
    ah, ok then. i’ll be interested to See the end result, i can’t think right now how i’d do it either!
  • Warren Beard
    5 September 2007 at 12:09
    could you not attach something like this to the flag poles, rivet the Dibond into the channels and it’s done?
    http://www.jagsignsupplies.com/aqshop/c … php?id=512
    Warren
