Home Forums Software Discussions General Software Topics What are PLT & PRM files
  • What are PLT & PRM files
    Posted by Russ on 23 April 2006 at 19:43
    Have been given a disc and it contains PLT & PRM files, can anyone please tell what they are and can I cut from them, if not can I print from them, they will not open in flexi 7.
    Russ
    Marekdlux replied 19 years, 7 months ago 6 Members · 8 Replies
  • 8 Replies
    23 April 2006 at 19:50
    russ prm dosnt ring a bell but plt is hpgl plot file, you shoul be able to import to flexi, if not email it to me and I will see if I can convert for you
    23 April 2006 at 20:08
    sounds like Gerber files
  • Russ
    Peter I have tried to import it a few times each time a small window pops up with something to do with resolution I have then ok it and nothing happens just blank screen.
    Russ
    23 April 2006 at 20:13
    it wont… its gerber…sadly i wont be using Gerber software for a few days… also see this
    http://www.uksignboards.com/viewtopic.php?p=121660&highlight=prm#121660
    Gerber has there own PLT format.. which does not follow the trend of HPGL.. PRM something linked with Gerber software i think, might be a router line, not sure.
  • Russ
    23 April 2006 at 20:20
    Thanks chaps I will call them tomorrow and explain.
    Russ
    24 April 2006 at 07:45
    PLT tends to be hpgl plot file but the Gerber did have its own variation. Not heard of prm but I have heard of prn which is a print file (typo?) both of these formats will import into Signlab and Corel – prn would need to be postscript though.
    Alan D
  • Dave & Rob Lowery
    24 April 2006 at 07:50
    Russ, a plt file is for gerber and a prm file is a file that is set up by the aforementioned for the different parameters thet the job was cut at. I you can post the plt file on here or pm me for my email address, i can open it for you and send it back as an eps file.
  • Marekdlux
    24 April 2006 at 22:04
    As was said before. PLT and PRM are gerber files. the PRM is usually a temp file saved when you output you file that carries all the information on the size/quantity/etc. I usually delete those from my system because if I ever cut it again, I usually don’t cut the same amount or use the same size material.
    PRM might also be the file that you save your router files under as well using ArtPath software from Gerber. Can’t quite remember that one, but I delete those as well because of the same reasons.
    -Marek
