Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters what are peoples opinions on the Creation PCut630 please?
  • what are peoples opinions on the Creation PCut630 please?
    Posted by Gav on 5 March 2006 at 14:50
    Are these any good? I am not intending to use it for heavy use but it seems like a good buy at £500.
    Gav.
    Chris Whitehead replied 19 years, 8 months ago 6 Members · 9 Replies
  • 9 Replies
  • Brian Hays
    5 March 2006 at 15:02
    They are a bit like older Rolands. Pretty solidly built.
    They won’t win any prizes for speed but get there eventually 😀
    I would buy it from somebody in the UK for piece of mind though, there are a few people selling them direct from China I think.
  • Dale Hughes
    5 March 2006 at 15:56
    I have just Bought one of eBay but from all the post on here i made sure it was from Alan Flynn i had a couple of setup issues but all works great no problems as yet but i know that if i do get problems i can call Alan and he will help me sort it
  • Gav
    5 March 2006 at 16:45
    Thanks guys.
    I take it 600mm is the most common size of cutter and should be pretty good for most types of work.
  • Brian Hays
    5 March 2006 at 20:21
    Gav Vinyl is normally manufactured in 4′ logs, so suppliers only have to chop it in half. 2′ is a pretty good size to have.
  • Mark Reed
    5 March 2006 at 20:27
    I’ve had mine a while, no problems so far, there are 2 different models though one uses com port 1 the others use usb, I found the com port model less of a problem with window’s XP, although the usb was not to much of a problem to set up either. I would also stress like the other’s buy from a reliable UK source such as the afore mentioned Alan flynn, he also set up my computer for me to run the software etc, and spent a couple of hours going through the basics with me,
  • Gav
    5 March 2006 at 21:07
    I have seen a UK seller called “Signwizard UK Ltd”. Has anyone had any experience with him?
    He is selling the Procut PC-700 cutter for £500 inc.
    Spec.
    * 610mm Cutting Width
    * 4MB Memory upgrade included FREE
    * 700mm Media Width
    * 500mm ps Cutting Speed
    * 500 grams of force
    * USB, Serial & Parallel port connections
    * Z-TEK USB>Serial adapter
    * included FREE Cuts vinyl films
    * 3 Blades included
    * LCD Control Panel
    * FREE Floor Stand
    * Dust cover
    * Plotter Pen
    * 1 Year RTB Warranty
    * Bundled cutting software
    It doesnt look like a bad deal for the money. What do you think?
  • Mark Reed
    5 March 2006 at 21:20
    seems like a good deal to me, although I noticed that it seems to only have a usb connection via an adaptor, this shouldn’t be to much of a problem but I did find that when I had to use this method of connection I had to set up a usb port as a com 1 port and slow the transfer rate to the cutter down a bit, not to hard to do and I know nothing about computers as such so any one with a little knowledge shouldn’t find this a problem, is it sign wizard who were selling the application tape dispencers, if so I did buy one of these from them this was also a good deal and if you are just starting out I would advise getting one you won’t regret it.
  • Alistair Richards
    10 March 2006 at 18:02
    I bought my plotter from SignWizard, and they’ve been very helpful, speak to Paul on the tech number if you need any questions answering, they also do the app dispenser at a good rate if you buy with a cutter.
  • Chris Whitehead
    4 April 2006 at 12:41
    Yeah, I too bought the same one from Alan Flynn, and i’ve been very impressed with it.
    Alan was also great in helping through a few small teething setup problems…
