Home Forums Sign Making Discussions Neon, LED, Lighting what adhesive can i use to glue dibond and perspex?
  • what adhesive can i use to glue dibond and perspex?
    Posted by joesignalsigns on 3 May 2005 at 10:31
    does anyone know of a good outdoor adhesive to glue dibond and perspex
    together without the glue "sucking" through the dibond
    CAT replied 20 years, 7 months ago 1 Member · 1 Reply
  • 1 Reply
  • CAT
    3 May 2005 at 14:10
    Joe, the last place I used to work at, we used a liquid glue for most things to do with perspex, I’m sure if you phoned my x boss he would help you out with the name of the glue and where to get it from, here is the info.
    The company is called Modern Engraving and its in Stoke on Trent, the guy you need to speak to is Brian Ireland, and the phone number is 01782 849055. Hope this helps, cheers Tony.
