Home › Forums › Printing Discussions › Roland Printers › watermark on print job, help
Posted by Lynn Wang on 26 February 2016 at 12:46Hi,
my printing job is coming with watermarks, photo attached.
Could anyone advise what could be the reason and solution?
printer is roland VS640-i, 8 colours
PETER SUNG replied 9 years, 8 months ago 7 Members · 9 Replies -
do you mean the marks under the laminate?
looks it’s the adhesive, probably a pressure issue, would depend on what laminate you’re using, I sometimes get marks or silvering but it generally just disappears in a few days.
The other thing might be that the print wasn’t left long enough to gas out properly, causing some kind of reaction with the adhesive.
Seen this a few times when we are requested to do rush jobs. Mainly because the print weren’t left to gas out long enough. But usually it does slightly go the next day 8).
It was not laminated, just have lots of marks after printing.
material is Avery range self adhesive AU6670005
Maybe a silly question but have you tried using a different media just to see if it still happened.
It may be too much ink and/or not enough heat?
Is it a generic profile being used or the correct one for that material…..
I sometimes get that effect on a high speed, heavy ink load with not enough heat. Especially red.
I have the same printer I think it’s contaminated media, perhaps light dust is sitting on the media before the ink gets to it.
Try different media.. note I usually push about 20-30 cm of media forward to avoid any media with potential to hold dust /specs on it, I’d also do a maintenance clean on the head in case it’s that.
