Home Forums Software Discussions General Software Topics Wasatch Softrip 6.2
  • Wasatch Softrip 6.2
    Posted by Rod Gray on 4 February 2008 at 16:31
    Hi Guys,
    I`m using the above rip with my grenadier and i find i`m having to rip the same image every time i want to print it.
    Wasatch has no save utility (well none that i have found) that lets me rip it once and print it as many times as i`d like. Is there a way to save the rip so i can quickly load it and print it?.
    Rod Gray replied 17 years, 10 months ago 2 Members · 4 Replies
    4 February 2008 at 16:37
    hi rod
    i using the lesser colour rip are you using rip and print or rip only then choose what to print from the list.
  • Rod Gray
    4 February 2008 at 17:13
    Hi Chris,
    I`m designing the print and saving it as a jpg in Coreldraw.
    I`m then opening the jpg in wasatch and then hitting RIP and print.
    I had been using the queues tab to repeat cut but i prefer seeing what i`m about to print before hitting the button. Also, those RIP files seem to eat up a hell of a disk space on my primary drive.
    Is this how youre doing it?.
    4 February 2008 at 18:28
    hi
    i would not bother to export vectors as jpegs unless you have a reason eps will do fine.
    setup the print modes and rip only.
    go to the print queue immediate print should be off.
    double click the file you wish to print, a preview and size info should come up also asking for quantity of prints. no off prints 1 or what ever.
    set manual print layout to on. click layout and will show you where its going to print. you can also move the print with the mouse to reposition it.
  • Rod Gray
    5 February 2008 at 08:08
    Thanks Chris,
    Came in this morning extra early to try out your method. It`s just what i`m after.
    Thanks a lot mate, really appreciated.
