Home Forums Printing Discussions Uniform Printers wasatch problem
  • wasatch problem
    Posted by Colin Hibbitt on 10 November 2010 at 08:50
    Hi Guys
    Noticed problem trying to print Aqua the other day using our usual profiles
    been fine in the past on repeat jobs but no longer
    Been on to wasatch and tech 8 who inform me its a profile issue – ive installed 3 profile of which they sent of which one is working perfectly but it prints at 720×360 – i tried to change to 720×720 but upping the passes but this again turns the image to green
    I had reinstalled the actual profile which came with the machine (grenidier2)
    on the disc but again the aqua is green
    printing direct from signlab the colour is fine but unable to print cut laminate due to lack of use in this department
    ive tried the atlas colour generator which again prints with green tinge so cannot produce the colour i need –
    any offers of help at this point will be grately received
    or if anyone has a profile for MD5 for the grenidier i could try
    colin
    Colin Hibbitt replied 15 years ago 3 Members · 4 Replies
    10 November 2010 at 09:24
    colin
    is this with pre riped files or new eps’s perhaps the eps export has altered its output profile.??
  • Steve McAdie
    10 November 2010 at 09:29
    Have you tried the profile from metamark site Colin.
  • Colin Hibbitt
    10 November 2010 at 09:47
    HI CHRIS
    we export from signlab as a level 3 eps which we do all the time – it doesnt give me the option to change any setting for the eps
    its only this week we started havingthis problem – trying all sorts of profiles if have – the only one which work fine are the ones with only 2 head passes
    when i try to change to 8 passes it seems to go back to green
    Steve i have just contacted metamark to try to obtain a profile for this – we have already md5 profile installed but these also print green
    very confusing
  • Colin Hibbitt
    10 November 2010 at 12:16
    might be getting somewhere
    had some new profiles sent to me which work – tech8 reckon my yellow ink may be to vibrant??
    sending him a sample to check
