Home Forums Sign Making Discussions Vehicle Wrapping VW Transporter door handles
  • VW Transporter door handles
    Posted by Jan Storgaard on 7 August 2010 at 10:29
    I need to wrap front and sliding doors on a vw transporter (new) and need to take out handles. Any advice on that ?
    Like small things falling to bottom of inside the door ;o) – or do they just come out in one piece ?
    Jan
    Matty Goodwin replied 15 years, 4 months ago 2 Members · 3 Replies
  • Matty Goodwin
    7 August 2010 at 11:12
    Hi Jan
    The front door handles are simple enough. Just undo the hex nut on the inside of the door, pretty much level with the handle. (not the three nuts in a triangle underneath the nut!). Then pull the handle and pull to the side. It should be as simple as that.
    As far as I remember the side door should be the same.
    Matt
  • Jan Storgaard
    7 August 2010 at 11:18
    quote Matty Goodwin:
    Hi Jan
    Matt
    Thx, when putting them back, you have to kinda restrain handle in "open position" ???
  • Matty Goodwin
    7 August 2010 at 12:10
    No, I don’t think so. You do the reverse of what you did to take them off. (I think!)
